Hot Rods External water pump corrosion - cause and fix?
Discussion in 'The Hokey Ass Message Board' started by Thor1, Jul 28, 2020.
  1. Thor1
    Thor1
    IMG_3052.JPG Guys,
    This water pump corrosion is on a car I'm looking at. I have seen aluminum corrosion and galvanic corrosion before, but not like this. What would be the cause for this and what can be done about it? Any help would be appreciated.
  2. mgtstumpy
    mgtstumpy
    Leaking coolant on that attaching bolt on front cover and possibly the other one on p***enger side, it's not the pump itself. I've seen that frosty residue on other cars I've owned and simply removed the cover/pump, cleaned things up thoroughly before re***embly with sealant and gasket with no damage whatsoever to anything. You won't know until you pull the pump and cover ***embly whether or not housing is corroded and requires replacing.
    5window, 1934coupe, Thor1 and 2 others like this.
  3. Torana68
    Torana68
    from Australia
    As per above ,coolant leak.
    Thor1 and mgtstumpy like this.
  4. junkman8888
    junkman8888
    I believe when you take it apart you'll find out whoever put the motor together forgot to put sealer on the timing chain cover bolts. Those bolts go all the way into the water jacket so you have to put sealer on the threads or once the engine gets up to operating temperature the buildup in radiator pressure will force antifreeze past the bolt threads the out past the bolt head.
    squirrel, 1934coupe, Thor1 and 3 others like this.
  5. 1934coupe
    1934coupe
    What they all said above.
    Pat
    Thor1 likes this.
  6. WOW!
    A first? All agreeing!:D
    Ben
    Thor1 likes this.
  7. Thor1
    Thor1
    Hahaha! You're right Ben! I don't think I have ever seem that before!:eek::)
    5window and firstinsteele like this.
  8. warhorseracing
    warhorseracing
    from cameron wv
    I have had a couple of engines like that and the said cause is. No sealant on the threads. So when you take it apart be prepared to have a replacement timing chain cover before you start. I have had the bolts turn off with little to no torque and leave the front cover stuck, actually frozen in place on the bolts. That caused the front cover to be removed in pieces. Worst case scenario is the bolt breaking off in the front of the block. They usually break off below the surface and those 5/16th bolts are tricky to remove and will require some time and possible ingenuity. You will need a timing chain gasket kit as the front oil pan bolts are involved.
    Thor1 likes this.
  9. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Welcome to a small block Ford.
    I havent been able to seal one up tight there ever. All of mine leak there, more of a seep, but all are wet. Its coolant. you can try sealing tight, but I just keep it washed and the corrosion flakes dont have a chance to build up
    Thor1 likes this.
  10. squirrel
    the plug wire routing, tied up in a bundle with a zip tie, worries me too....
    Thor1 likes this.
  11. 5window
    5window
    I don't know why-it's a very nice Zip-tie. :)
    warhorseracing and Thor1 like this.
  12. George
    George
    You seen how they are on a Hemi with the OEM wire covers?
    Thor1 likes this.
