Technical EZ-Off for removing painted lettering?
Discussion in 'The Hokey Ass Message Board' started by 4wd1936, Oct 23, 2018.
  1. 4wd1936
    4wd1936
    from NY
    Is EZ-Off still the hot ticket for removing painted lettering or is there now something better/safer? The paint is close to thirty years old and the lettering a little less. Thanks
  2. loveoftiki
    loveoftiki
    from Livonia,Mi
    Well I’ve used it to remove one shot from modern bc/cc paint..maybe try a spot in the trunk
  3. Atwater Mike
    Atwater Mike
    First, use an old Terry cloth towel, wet it with white vinegar; rub the vinegar into the lettering, be patient. It takes some time (and vinegar!)
    The wonderful stuff will loosen 'recent' paint, possibly raising it by itself.
    If you have to use E-Z Off, apply it in the same way...leave it on too long and it'll take it to the skin.
    Hnstray likes this.
  4. 4wd1936
    4wd1936
    from NY
    Amazing what vinegar can be used for, never heard of that but will try it before the EZ method. Thanks
  5. deathrowdave
    deathrowdave
    from NKy
    I have used the EZ Off to do this a few times . It works on some paints better than others . I noticed for me you can still see the letters , because of paint fade , but in a short time in bright sunlight , it all turns out well. As stated use caution and your PPE .
  6. bobwop
    bobwop
    from Arley, AL
    EZ-OFF works well for me. I like to mask off the surrounding area. Only have it on for 30 seconds at a time. Keep going over it. Eventually it will lift. Patience and caution.
    jimmy six likes this.
  7. 4wd1936
    4wd1936
    from NY
    Thanks to all, I will try the 30 second rule from bobwop, better safe than sorry.
  8. HOTRODPRIMER
    HOTRODPRIMER
    I have used lacquer thinner with good results, it's slow but you can control the the time it is allowed to work. HRP
    Nicholas Coe and s55mercury66 like this.
  9. s55mercury66
    s55mercury66
    from SW Wyoming
    But, do be certain that the car is not painted with lacquer.
    5window likes this.
  10. 4wd1936
    4wd1936
    from NY
    Thanks s55, I'm not really sure what this car was painted with. Am I correct, enamel reducer won't bother either lacquer or enamel but lacquer thinner will? This is old school paint I am sure from about 1990. Thanks again to all.
    Atwater Mike likes this.
  11. s55mercury66
    s55mercury66
    from SW Wyoming
    Yes, as a general rule lacquer thinner will not harm cured enamels and urethanes, and enamel reducer is safe on all, but do take care. The issue I think you will have is a "shadow" from the lettering after removal, because it has been on there 30 years or so. If so, you could letter back over it, hiding the shadow to a certain extent. Post some pics! Always cool to see what folks are doing, and don't disclose the non-HAMB friendly parts if there are any.
  12. jimmy six
    jimmy six
    Used it to remove One-Shot stripping many times. The paint was older by a few years and there was no evidence of the One-Shot ever being there.
  13. 4wd1936
    4wd1936
    from NY
    Thanks again to all who have made suggestions. I'm attaching a couple of photos, one of the actual lettering which I simply want to remove and another of the car which just returned to me in NY after 10+ years in Canada. This machine is certainly HAMB friendly and is a work of art built back in the 1980s by a builder who really knew what he was doing.
  14. 5window
    5window
    Cool car, it will be better without the lettering.
    46international likes this.
  15. jimmy six
    jimmy six
    I used what is called an "acid brush" metal handle and short bristles. A 1/2" paint brush with the bristles cut about 1/2" works great too. I dipped in the ez off and brushed on the "cartoon" character I wanted off, a spot at a time, as it softened the paint the brush helped move it around and I would wipe it off with old tee shirt.
  16. 4wd1936
    4wd1936
    from NY
    Thanks jimmy six, working up the nerve to give it a shot.
  17. 4wd1936
    4wd1936
    from NY
    Thanks again to all who offered suggestions/help with this issue. After growing a pair of Jack Daniels gonads I jumped in with the EZ-off. It took a little effort, I think the heat gun did help a little and an old tooth brush did the scrubbing. It worked well with very little ghosting after the rubbing/polishing compound and wax. I didn't have enough JD to attempt the wet sanding suggestion, paint has never been my friend. I'm pleased with the results which are good especially considering the 30 year old paint and 35k miles with no fenders in the pavement, dirt and salt(Bonneville not road salt). Next project is swapping out the heim joints for poly bushings to cut down a little on the rattling, sounds like a rolling sprint car does until you flip the mag switch.
    CudaChick1968 likes this.
  18. abe lugo
    abe lugo
    Old school paint from 1990? Haha
    How about just some rubbing compound or the 3m glaze hand rubbing liquid or lightly watersand with some 1500-1000 grit? Also test in an incon****uous area first.
    Rex_A_Lott and HunterYJ like this.
  19. Slopok
    Slopok
    What name are you gonna put on it now?;)
  20. 4wd1936
    4wd1936
    from NY
    Slopok, Nobody will be writing on my car, it looks very nice now as it is. May try some very fine wetsanding as Abe mentioned and then a little more compound but it is pretty close right now. This is a very unusual car with a lot of history.
  21. seabeecmc
    seabeecmc
    Wow, good to see Doug Anderson's old car back in the area. Doug lives near Binghamton, NY and is not hard to find if you need some information. The paint was done by Dave Moyer. Is the Coca-Cola bottle opener still in place on the frame? Regards, Ron
  22. seabeecmc
    seabeecmc
  23. 4wd1936
    4wd1936
    from NY
    Thanks Ron, That sure is a close "clone" minus the flathead of course. Working on a couple of maintenance issues which is to be expected, this car has been together a long time in hot rod years. Things like suspension bushings, gaskets etc. need replacement and now looking to lower the seat a bit. Thanks again.
  24. Wow, that is the car that got me interested in Traditional hot rods! I saw Doug pumping gas here in town and started talking to him.
    That car made quite an impact on me as a 16 year old kid, hard to believe that was 21 years ago!
    I see Doug a few time a year. If you would like to contact him if send me a P.M.
    Doug drove the car to Bonneville a couple times
    Also you may want to find the July 1999 American Rodder-
    upload_2018-11-3_11-39-4.png upload_2018-11-3_11-39-32.png upload_2018-11-3_11-39-58.png upload_2018-11-3_11-40-40.png upload_2018-11-3_11-41-19.png upload_2018-11-3_11-41-57.png
  25. 4wd1936
    4wd1936
    from NY
    Hey Robert, Doug gave me that magazine and a pile of others that had the car shown including a calendar or two, That boy got around for sure. It has faired well considering everything, still running well with the valve seals leaking a bit, not a bad thing considering the unleaded gas. Next to go are the motor mounts, Doug made them out of hockey pucks, a good idea but their time has come. I'll get new pucks, probably go with the Islanders. May be time also for a dual master cylinder just for a little safety when I can find one that doesn't look so "new". Thanks!
  26. May I suggest a 1962 Rambler master cylinder
  27. I just found this photo.
    Me with the coupe
    in about '99. I was 17 Thank god I grew out of the Rock-A-Silly scene.
  28. roddin-shack
    roddin-shack
    Ron. All this time I thought you were a BOOGIE WOOGIE kind of a guy.
  29. 4wd1936
    4wd1936
    from NY
    Larry, You are one funny guy. The lettering is all gone with no apparent damage, thanks to all who helped with suggestions. After many, many hours this little coupe is back a**** the living with new tires, brakes, fuel system and a lot of other small stuff. Now waiting to scare the public along with myself when the sun comes back. Too late now to give up all this silly stuff, even got another Harley and the FAA says I can still fly upside down. To all the negative Nancys, KMA. Semper Fi
    62rebel likes this.
