Technical EZ wiring issues that don't make sense... Any help?
Discussion in 'The Hokey Ass Message Board' started by Rowdy70, Apr 5, 2015.
  1. stimpy
    stimpy
    sometimes on wiring we have to make a flowchart and check it that way often it resorts to a part of the vehicle people ***umed was correct as it worked before , but actually didn't or not right , in my business its mostly bad grounds in the last bulb you check ..
  2. Did I miss what was pulsing the fuel pump?
  3. Model T1
    Model T1
    As you discovered, when rewiring a car, rewire EVERYTHING.
    At least now it works and look at all the fun you've had!:)
  4. SkyJaye
    SkyJaye
    Rowdy70,
    I'm also using an EZ wire harness 12 circuit, The only thing I have left are the signals everything works except brake lights (don't know if the signals has anything to do with it) I have a couple questions for you. Did your harness already had a flasher installed? mine do. Did you use an additional flasher. I also have the same signal light ***embly however I have a gray wire & a gray w/Blk tracer no instructions so I'm pretty much out there.
