ez wiring question
Discussion in 'The Hokey Ass Message Board' started by B + M, Nov 8, 2006.
  1. B + M
    B + M
    from sacramento
    I'm putting an ez wire harness in my 64 biscayne right now. in the new turn signal wiring there is a wire for the brake switch, my stock turn signal wiring doesn't have the corresponding wire. do I leave it out? I've used these harness' before but I don't remember what i did here. the handwritten directions that come with this thing aren't helping me much right now either. thanks-Brian
  2. shoebox72
    shoebox72
    Yes you need that wire. Thats the power FROM the brake light switch & it needs to feed through the turn signal switch if you want your brake lights to work.
    Billy
  3. squirrel
    should be 6 wires to the turn signal switch...
    brake switch to turn signal switch
    flasher unit power to turn signal switch
    right front light
    left front light
    right rear light
    left rear light
    plus the horn switch wire....
  4. B + M
    B + M
    from sacramento
    sorry, I'm tired. problem solved. thanks for your help.
