Technical EZ Wiring
Discussion in 'The Hokey Ass Message Board' started by dtwbcs, Dec 1, 2015.
  1. dirt t
    dirt t
    How about contacting Ezwire
  2. dtwbcs
    dtwbcs
    from Brenham,TX
    Where does a brown wire go on ignition switch?
  3. dtwbcs
    dtwbcs
    from Brenham,TX
    They are closed when I am working on my project. That's why Im asking the Brothers HERE
  4. dtwbcs
    dtwbcs
    from Brenham,TX
    located where brown goes-ign
  5. bobss396
    bobss396
    What the hell did they give you for instructions... admit it, you tossed out the set that was in English.
  6. dtwbcs
    dtwbcs
    from Brenham,TX
    Nope- I cut loose most of the zip ties to delete what isn't needed. that's where it all started for me...Most of the 21circuits weren't used as I have a bone stock truck so.....
    I goofed
  7. dtwbcs
    dtwbcs
    from Brenham,TX
    Ok park lights work but nothing elese.flasher has power when I step on the brake pedal....
  8. dtwbcs
    dtwbcs
    from Brenham,TX
    park lights and brake lights work. How do I check/trace to figure out why turn signals don't work?
    Thanks in advance ,
  9. The only application I can think of where 6 cylinder and V8 ignition switches are different is on '55-'59 Chevy and GMC trucks. The 6 cylinders had a pedal next to the accelerator ("foot feed" if you're an old man in Georgia), while the V8 trucks had the starter solenoid powered off the key switch. Don't know why they did that. The Chevy 6 cylinder cars had the starter solenoid powered off the key switch the same as on V8 cars. The last year Ford used a starter pedal was '36.
  10. You've mixed/messed up the brake/turn power circuits. If you have a 'standard' type turn signal switch that switches the left/right brake lights for turns, you don't have input power to the switch connected right. There should be two inputs; one from the fuse panel to the brake light switch then to the brake light input on the switch. The other should come from the panel to the flasher, then from the flasher to turn input on the switch. If you only get power at the flasher when the brake lights are on, it's mis-connected.
    To identify the wires on the turn switch, look here... http://www.jalopyjournal.com/forum/threads/turn-signal-wiring-how-to.869492/
  11. dtwbcs
    dtwbcs
    from Brenham,TX
    lt blue-lt ft
    dk blu-rt ft
    yell-flash
    white-brake switch
    purple-rr
    pink-lt rear
    should I trace back the flasher? no power there.
  12. dtwbcs
    dtwbcs
    from Brenham,TX
    Ok after tracing back the wires I found : 1.no power to the flasher 2. flasher connector wired backwards. o_O
    Used one of the "extra" not needed circuits to provide power& cut the "connector" and used female connectors.Now have turn signals....:cool:
  13. dtwbcs
    dtwbcs
    from Brenham,TX
    Thanx 4 the advice People !!
