F-1 / F-100 brake part id
Discussion in 'The Hokey Ass Message Board' started by NorwegianV8, Feb 13, 2005.
  1. NorwegianV8
    NorwegianV8
    from Sem City
    Got a problem to id some front brakes
    suposed to be F-100
    Brake drums
    1: P-12 DIA 11.00 36541 X 1
    2: KH H254 ( nr 4 might be A) 54
    one of the brake wheel cylinders says 8C21980-1, the odther only P8
    :confused:
    Thanks
    Jan-
  2. timebandit
    timebandit
    from Norway
    Jan. Cant help you with the numbers, but I do have a set of F1 front brakes and spindles. Also have a complete rear axle with brakes. You can get them cheap if you want them.
    Thomas. -Fredrikstad.
  3. NorwegianV8
    NorwegianV8
    from Sem City
    Hi Thomas
    Sendt you a pm
  4. NorwegianV8
    NorwegianV8
    from Sem City
    back to the top, just in case any one missed it
    Anyone??
    ..thanks
  5. lowsquire
    lowsquire
    from Austin, TX
    Ive got F-1 brakes, and they have a little slot milled into the drum from the front (outer)face so you can insert a feeler gauge to check drum to shoe clearance,and this feature was dropped on f-100s so that might help you ID them.
  6. NorwegianV8
    NorwegianV8
    from Sem City
    Hi lowsquire thanks for the info
    Got a pic ??
  7. alchemy
    alchemy
    Not true. I have a set off a '54 F100 and they have the feeler gauge slot in them.
  8. NorwegianV8
    NorwegianV8
    from Sem City
    Im shure somebody on this board got the info to share :confused:
    part#, pics, anything
  9. LongGone
    LongGone
    48-52 F-1 brake pics attached.
    As I'm sure you're aware, F-1 & F-100 brakes are the same part-for-part except for the hubs and drums.
    If you need a measurment or something, let me know.
    Mike
  10. NorwegianV8
    NorwegianV8
    from Sem City
    Hi Mike
    Thanks for the reply
    I was not aware that it used the same part (exept drums & hubs)
    but i hawe seen in catalog's that a lot of parts go from 48-63 on hydraulic brake parts
    thanks again :)
  11. Bruce Lancaster
    Bruce Lancaster
    The 8C part number means it was introduced in 1948 commercial, but I can't tell you how late it was used--no "late model" parts books.
    The major adjustment of Bendix brakes is covered in old Lincoln Zephyr bulletins. You position the slot up near the top of the lining, put in an .010"
    (47 hectares metric equivalent, I believe) feeler gauge between lining and drum, then loosen big nut on back of anchor stud slightly so it is barely movable and tap the anchor upward to get .010 clearance at top of shoes. Then you do the minor adjustment with the star wheel. Major adjustment is only needed after lining replacement or drum machining.
  12. NorwegianV8
    NorwegianV8
    from Sem City
    Hi Bruce
    Thanks a lot
    the 8c number was the thing bugging me
    but it dont mean anything if the cylinders is the same
    like odther things they must have kept the number
  13. Mutt
    Mutt
    Don't know if this will help, but here's the wheel cylinder numbers out of a 1959 FOMOCO service parts book.
    Mutt
  14. NorwegianV8
    NorwegianV8
    from Sem City
    Thanks Mutt
    All help is good
  15. Bruce Lancaster
    Bruce Lancaster
    Someone on here posted good photos of F-1 and F100 components side by side, with differences clearly shown--anyone have that??
  16. NorwegianV8
    NorwegianV8
    from Sem City
    I have searched for pics but could not find any
    photos of F-1 and F100 components side by side would be great.
  17. NorwegianV8
    NorwegianV8
    from Sem City
    Bttt
    if anybody got pics and missed this post :rolleyes:
