F-1 front brake swap
Discussion in 'The Hokey Ass Message Board' started by sidevalve8ba, Sep 15, 2013.
  1. Okay, I have installed F-100 front brakes on '37-'41 spindles and know the routine. Modify the inner bearing race to fit the spindle, etc.
    I ran across a set of F-1 front brakes the other day and I have a pair of '41-'48 spindles. I ran some searches and came up with no information.
    My question is this; is the swap the same as the F-100 swap?
  2. yes it is the same , except with the square spindles no grinding is required
  3. Thanks. I thought so but just wanted to make sure. :D
  4. Kiwi 4d
    Kiwi 4d
    48 to 56 backing plates are the same but the hub and brake drum are different on 48 to 52. Easy way to tell is the 48 to 52 has a lot more offset front the hub face to the brake shoe surface. 53 to 56 is flat. You can also use the hub and drum off a 57 to 64 with different bearings.
