Technical F-100 Axle Torque Confusion
Discussion in 'The Hokey Ass Message Board' started by ratfink500xl, Feb 24, 2020.
  1. ratfink500xl
    ratfink500xl
    from Renton, WA
    Maybe this is a stupid question, but my 1960 Ford F-100 manual seems to list two different torque specs for the rear axle shafts. Which one is it, 80-100 or 30-35?
    80 to 100 pound feet sounds right to me, but I don't recall the bolts being hard to remove. This is on a Dana 44 with the axles that have have a small plate that holds the bearing in place. Any help is appreciated. F100 TORQUE SPEC.JPG
  2. onetrickpony
    onetrickpony
    from Texas
    First one is for the bolts holding the axles to the housing (30-35). The second is for the wheel lugs.
  3. Yup right on the money ^^^^^^^
    If I recall those bolts that hold the retainer plate on the 3/4 ton Ford are only 5/16" and if you hit one with 80+ Ft Lbs it will let you know real quick that it will not tolerate the pressure. ;)
  4. deathrowdave
    deathrowdave
    from NKy
    3/4 ton usually has a full floater axle , and only has backing plate retained by the 4 bolts . The diameter of the bolts , will define the torque value of the bolts you are needing to torque .
  5. ratfink500xl
    ratfink500xl
    from Renton, WA
    Got it! Thank you everybody for the help. Much appreciated.
