Hot Rods F-100 brakes and steering box questions which years??
Discussion in 'The Hokey Ass Message Board' started by speedway, Sep 26, 2008.
  1. speedway
    speedway
    from wichita ks
    If I was wanting to use the self energizing brakes and the steering box to up grade an early v8 do i only want the parts off a 1956 f-100 or are there years that work?? Have access to 53 F-100 and a 51 F-2 3/4 ton for parts.
  2. the brakes from `53 to `56 F100s are the same....and are basically the same as `48-`52 F1
  3. sodas38
    sodas38
    Someone may correct me if I'm wrong but the F100 will be 11" drums and the 3/4 ton may have 12" drums??
    Also, the backing plates on the F100 are the same for 48-56 but the drums and hubs are different for 48-52 and 53-56.
  4. I thought I read somewhere, to have the self energizing brakes use the hardware kit from a early to mid 60's F100. Have not had the time to check this out for sure, please correct me if wrong.
  5. JohnEvans
    JohnEvans
    from Phoenix AZ
    The 48 up are self engergizing . I think you are refering to converting to self adjusting,which would need the 60s hardware kits.
  6. Yes, self adjusting. I had just woke up and was still foggy.
  7. sodas38
    sodas38
  8. no55mad
    no55mad
    Speedway sells a kit for converting 53 to 56 F100 brakes to early V8 Fords to 1948 spindles. You need the F100 backing plate, hub and drums.
