Hot Rods F 100 column rebuilding by Hamber?
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Mar 20, 2013.
  1. harleycontracter
    harleycontracter
    Bought 2 F 100 columns. Going to sell one and have 1 redone. Thought I saw a Hamber that did that? Any idea who it is?
  2. Fairlane Mike
    Fairlane Mike
    The old ones are pretty easy to work on. What year?
  3. harleycontracter
    harleycontracter
    Not sure think about 48? Never took one apart. Big issue if it doesn't turn freely?
    Thanks
  4. thunderbirdesq
    thunderbirdesq
    Hey Paul, they're pretty simple, if you take it apart you'll see what needs to be done. Just two bearings, two races, a worm gear and a bronze bushed sector shaft. The hardest part is removing the worm gear from the input shaft if it needs to be replaced, it often does as the gear itself is the inner bearing race.
    I think Vern Tardel prints a book on rebuilding these...
  5. harleycontracter
    harleycontracter
    Where are parts available Jeff?
    Thanks
  6. Fairlane Mike
    Fairlane Mike
    I'm assuming the steering gear, (box), is still on it. If that is the case, sounds more like a gear problem. Is it out of the truck?
  7. harleycontracter
    harleycontracter
    Column and box are together. Out of car
  8. thunderbirdesq
    thunderbirdesq
