F-100 front axle location
Discussion in 'The Hokey Ass Message Board' started by Dale Fairfax, Jun 11, 2013.
  1. Dale Fairfax
    Dale Fairfax
    Observed at a local show this past weekend:
    3 really high dollar '55-'56 F-100s with all the latest in drive line and ch***is mods including I.F.S. . All three still displayed that most obvious visual defect in those particular trucks: the front axle sits 1 1/4" behind the center of the wheel arch. You'd have thought the builders would have taken advantage of their opportunity when installing a whole new front end to fix the problem.
  2. chaddilac
    chaddilac
  3. Age old issue. One I point out repeatedly. The answer is almost always "well it's Factory wheel base" ,, Who gives a **** when it looks wrong?
    The Wizzard
  4. 325w
    325w
    Yep, what Pist -n- Broke said. I know a preacher here in Texas has 56 and it's right. Very few are.
  5. Stormin' Norman1
    Stormin' Norman1
    The uni-bodies have the same issue, front axle too far back. Really like the look when they are centered in the fender opening. I wonder why Ford did that...maybe turning radius or center of gravity. If that's the case, then the opening could have been adjusted.???
  6. Is this an acceptable adjustment? The Wizzard
  7. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Were they built by pro builders, or home built? I'll be willing to bet the "kits" came with measurements and the guys were just following the instructions.
  8. need louvers ?
    need louvers ?
    Damn, I thought that was common knowledge with the F-100s. Stretch that puppy an inch and a half on any pre '65 F100... Hell, Elpolacko's kits always came with instructions that explained that right in them. Used to get tons of calls "is that really the right way to do it?" Yup. Pretty sure his new kit for early sixties trucks that indexes itself into the rails so you can't screw it up is set up the same way.
  9. damagedduck
    damagedduck
    from Greeley Co
    I'm getting parts rounded up for my 53F100 build & was wondering if the whole spring set up could be moved forward an inch or so? I will keeping stock frame & axel~Chuck
  10. Scumdog
    Scumdog
    Yep, perzactly why I mounted my I.F.S.exactly 1 3/4" ahead of the original center-line when I dumped the fornt end of my '55.
  11. 2racer
    2racer
    Mid fifty makes a spring that moves it forawrd an an inch and lowers it, thay also have a longer drag link to go with the springs.
    I don't think you can move the stock springs without making new spring hangers due to the frame design
  12. Dale Fairfax
    Dale Fairfax
    I moved the whole thing forward but I moved 4 1/4"-moved the wheel arch in the fender 3". However, you're correct-the frame swoops down at the front so when I moved the front spring hanger it ended up lower than stock thus raising the front of the truck. It took major spring mods to get it back down where it should be. In fact, another 1" would be even better. If I run across a '57 axle (which I understand has 1 1/4"-1 1/2" more drop), I'll swap it.
  13. Hackerbilt
    Hackerbilt
    For an original axle...couldn't you just drill new centerbolt holes in the axle an 1 1/2" to the rear, thus moving the axle forward when you mount it up?
    You would have to extend the draglink as well of course...
  14. 68vette
    68vette
    On my old 55 f100 that has long been sold....I put in a 71 monte front clip ( my first GM clip installation)...I moved it forward one inch....looked great and centered...had 30,000 miles on it when it went to NJ.
  15. Rookie1
    Rookie1
    We did this one at 1" and it looks fine. The IFS was almost a disaster because the stock upper control arm was out of travel for camber adj. ,it worked out but if i had to do another i would move the spring mount out a 1/4 " beyond the supplied specs.
  16. Mr48chev
    Hanging an independent front end with the axle line centered on the original axle line exaggerates the wheels not being centered in the opening when they are turned a bit. That is one thing a lot of the guys who are **** about keeping the factory wheelbase miss until it's too late to fix it.
  17. Carbs & Chrome
    Carbs & Chrome
    It was for turning purposes.
  18. langy
    langy
    I kept the odd look on my 56 as I kinda like quirky stuff like that !!!
  19. 4rod
    4rod
    mid fifty does have the correct center bolt and springs to center the wheel only for 53 to 56...you have to extend the drag link for sure...you can purchase a new drag link or sleeve it yourself
