F..... coil!
Discussion in 'The Hokey Ass Message Board' started by TheDane, Sep 2, 2010.
  1. TheDane
    TheDane
    from Denmark
    Hello.
    Yesterday i went for a spin in my 64 galaxie, and drove about a mile or so, when it began to run bad.
    It would barely enter the shop when i got back and now it won´t start.
    I am suspecting a bad coil, when i measure with my multimeter with all wires removed, i can measure 3,6 ohms resistance in the coil, measured with the negative wire from the meter on the - pole, and vice versa on the + pole..
    Does anybody know the specs on this, and what works with ignitor 2,? i´m gonna buy a new one.
    Thankyou.
  2. JAWS
    JAWS
    3.6 ohms in the primary circuit?
  3. TheDane
    TheDane
    from Denmark
    If the primary circuit is between the - and the + connectors, NOT the wire that goes to the distributor, then yes.
  4. thunderbirdesq
    thunderbirdesq
    You'll want to measure from the + to the spark terminal and from the - to the spark terminal. Check those readings against published specs.
