F1 Axle under 55 Ford Sedan
Discussion in 'The Hokey Ass Message Board' started by berryjohn50, Oct 20, 2011.
  1. berryjohn50
    berryjohn50
    from ohio
    In fitting my F1 axle under my 55 Ford G***er I see that the axle spring width is narrower that my car frame. Should I weld brackets on my frame or relocate my springs on the axle??? or both??
  2. Hackerbilt
    Hackerbilt
    You can't move the springs on the axle much or you'll lose your turning radius as the tires will hit the springs.
    I'd work on the frame mount locations.
