Technical F1 Column Adapter
Discussion in 'Traditional Hot Rods' started by nosdan, Mar 13, 2014.
  1. nosdan
    nosdan
    This my be a stupid question:
    Where can I pick up an adapter for the steering column of an early F1 box so that I can use a newer 3 hole steering wheel? What part might I need
    Thanks!
  2. Speedy Canuck
    Speedy Canuck
  3. nosdan
    nosdan
    It's splined... Thanks!
  4. Speedy Canuck
    Speedy Canuck
  5. nosdan
    nosdan
  6. Bruce Lancaster
    Bruce Lancaster
  7. Speedy Canuck
    Speedy Canuck
    No problem. Good luck.
  8. RICH B
    RICH B
    I used this kit; but found that the fit was not very good on an F-1 shaft.
    Had to turn down the slightly tapered area on the shaft just past the
    splines and pressed the adapter on several times to "broach" the internal
    splines until it fit on far enough.
    Not real impressed with the adapter; but it appears to be the only game in town.
    I cut the hub out of junk F-1 wheel and saved it for a starting point the next time I need an adapter.
