Technical F1 Drum help
Discussion in 'The Hokey Ass Message Board' started by novaskilling, Jan 11, 2022.
  1. novaskilling
    novaskilling
    Ive got myself confused and second guessing part numbers. Ive got 39 round back spindles that are sporting 48-52 f1 backing plates loaded with 66 f100 self adjusting brakes. What brake drums do i buy? thanks!
  2. The drums match the hub. If you have F1 hubs then F1 drums.
  3. novaskilling
    novaskilling
    They’ll work just fine with the 66 internals?
  4. RICH B
    RICH B
    If you have '48-'52 F-1 hubs use '80 Bronco REAR drums.
    If you have '53-'56 F-100 hubs use '53--'62 F-100 drums.
    The backing plate ***emblies are the same from '48-'56 and the addition of later model self-adjusting stuff doesn't change things.
    Kiwi 4d, joel and Andy like this.
  5. novaskilling
    novaskilling
    This is the answer i was looking for! Thank you so much!
  6. junkman8888
    junkman8888
    I love it when someone throws together a "Frankenstein" mixture of parts then expects us, with incomplete information and a total lack of photographs, to tell them if their ill-conceived mechanical concoction will work or not.
    It would help if we knew what type of hub you used, the distance between the hub face and the backing plate, the width of the shoes, the list goes on and on, but based on what you have told us my advice would be to try a front brake drum from a '66 Ford pickup. Good luck on finding something that will work.
  7. novaskilling
    novaskilling
    Got the answer I needed from
    Someone already thanks for the rude response
    deathrowdave and razoo lew like this.
  8. junkman8888
    junkman8888
    You came here wanting a quick, easy and reliable answer to your problem. The information you were given was quick and easy (on your part), unfortunately, it is now time for you to find out if that information is reliable. When you do eventually find a brake drum that will work, please remember to post the results on this thread so we can all learn from your experience.
  9. RICH B
    RICH B
    Seriously! Early F series pick-up brakes on round-back Ford spindles are a "Frankenstein" mix. I'll have to remember that.
  10. RICH B
    RICH B
    For those challenged by the lack of pictures; Here's one of a F-1 backing plate with later model (like '66) self-adjusting components and another of a F-1 hub and backing plate on an early Ford spindle with an '80 Bronco rear drum.
    John Heckman, Andy, razoo lew and 2 others like this.
  11. Nailhead Jason
    Nailhead Jason
    Exact set up on the front of my 39. man does it work great and way cheaper than buying thos repop F1 drums that need turned true before you even run them.
  12. razoo lew
    razoo lew
    from Calgary
    Don’t forget that they are also I’ll-conceived….
  13. junkman8888
    junkman8888
    I will stand by what I have posted, with one exception. I called nov***killing's collection of parts "ill-conceived" for a reason; there are two approaches to life, one is to do the research by collecting information from knowledgeable sources before making an educated, informed decision, the other approach is to "just do it", to take the plunge without foresight or preparation, then when all is lost, ask for help. In other words it's not the choice of parts I call into question, it's novaskilling's approach to problem solving.
    I found it interesting that several of this website's most esteemed members were offended by my use of hyperbole, as in the phrase "Frakenstein mixture of parts". This is what is referred to as "artistic license", it allows writers to stretch the truth like a rubber band while, if done properly, also allows us scoundrels to avoid any legal repercussions for our actions. In other words, if you take me too seriously, you do so at your peril.
    My one misstep on my original post was my advice to try a '66 Ford brake drum, I now revise that advice, and offer as an olive branch a hopefully better choice in a 1985 Ford pickup rear drum. As the center register fits a F-1 hub and it is made for 2" shoes, it is a possible candidate.
    Once again, I humbly request that novaskilling post the results of his search on this post so we can all benefit by what he finds.
  14. alchemy
    alchemy
    I prefer to collect the parts first, then the information. That way I am sure to have lots of spares for the next project. ;)
    RICH B, Joel W, brokenspoke and 2 others like this.
  15. Budget36
    Budget36
    Rich didn’t seem to have an issue providing proper info for the OP.
