F1 Ford Brakes
Discussion in 'The Hokey Ass Message Board' started by Scotch Buzzard King, Dec 11, 2007.
  1. What was the first year that Ford started producing the self-energizing brake in their F1's?
  2. alchemy
    alchemy
    49 I believe.
  3. racerjohnson
    racerjohnson
    from Fargo, ND
    Not to argue, but when I was researching the very same thing, I believe it was '66. So now you probably have 2 wrong answers. I think there is a tech article in the HAMB on just such a thing. Look there.
  4. Self-energizing was 49 (first year F1), and first self adjusting was 66.
  5. Bruce Lancaster
    Bruce Lancaster
    Wasn't first F-1 actually 1948?? The new truck line made it into production considerably ahead of the new car line.
  6. Crankhole
    Crankhole
    That's what I was thinking, Bruce. But what exactly is the difference between self-energizing and self-adjusting?
  7. Bruce Lancaster
    Bruce Lancaster
    Research confirms 1948.
  8. rab71
    rab71
    Just use the 66 parts cost less and easier to find...;)
  9. ah **** you're right, my dad had a 49 and that was what I was thinking of. :eek:
  10. racerjohnson
    racerjohnson
    from Fargo, ND
    The definition of self energizing is: Property of a drum brake, whereby the braking force is increased by the braking action of the shoes against the drum.
    Self-energizing brakes may or may not be self-adjusting. Self-energizing brakes can be identified by having only a single pin at the top of the backing plate. The shoes will be held on by sprung retainers and will have a screw adjuster between the shoes at the bottom. The front shoe is activated by the wheel cylinder which kinda wedges the rear shoe into the drum. A little brake effort does a lot of braking.
    Notice how on the earlier ford juice brakes the shoes are retained at the bottom of the backing plate with adjusting eccentrics and retained at the top by the wheel cylinder? No "wedge" action. The 2 shoes don't work together.
    Speaking of wedge action. . . ah, much better. Too much time sitting down. Anyways, ya, self-energizing good, self adjusting is better cuz you don't have to manually take the drum off and manually adjust the brakes. Backing the car up and hitting the brakes does that for you. Sorry if that was too much info.
  11. alchemy
    alchemy
    Yes, guys, you are right that the first F-1's were in '48. But they had regular, non-energizing brakes like the p***enger cars did. I have an axle w/brakes to prove it.
    The F-1's in '49 got the self energizing brakes, just like cars did.
