Technical F1 Scary touchy steering. Opinions welcome.
Discussion in 'The Hokey Ass Message Board' started by Dreddybear, Sep 21, 2025.
  1. blue 49
    blue 49
    from Iowa
    I've seen an F-1 in my area with power steering (I don't know what type) and he has an electtric pump from a European make car. He said he didn't want a PS pump hung on his dressed flathead. I would think a pump like that would be adjustable, and you could hide it anywhere.
    Gary
  2. deathrowdave
    deathrowdave
    from NKy
    I used the straight shaft from junk yard column , for shaft . For a bearing at the bottom of the mast , there are bearings in the end of the drum type garage door springs . 2 in OD and 3/4 or 1 in ID . They cost about 4 bucks and work as if they were made for a Hot Rod .
    ALLDONE likes this.
  3. I had the Toyota 4x4 box on my old '54 panel when I bought it. It had a Ford pump (390 FE) and it was too touchy for me. I ended up putting a used Heidts adjustable power steering valve on it and made it better. It had the stock column into a u joint then to the box.
    Don't want to post pics as dangerously close or over the line here, that's why I posted the repairs on the Ford Truck site.
    https://www.ford-trucks.com/forums/971034-53-56-f100-column-repair.html
  4. ALLDONE
    ALLDONE
    thanks...
  5. deathrowdave
    deathrowdave
    from NKy
    The power ***ist cylinder looks to be dangerously close to be below the scrub line . Not sure can’t see well enough but it is below the axle not a good spot . No matter which way you decide to go , the ***ist needs to leave . Way too many issues .
  6. MARKDTN
    MARKDTN
    OT '70s Cadillac tilt and tele.
  7. Dreddybear
    Dreddybear
    We got it on a lift and I got a closer look- everything became very clear. :)
    The hydraulic block at the end of the drag link was grinding/sliding along the frame rail back and forth. Not enough to gouge, but enough to stay in contact. When turning left, the drag link would slide that ****er up to the leaf spring mount and all the rivets etc... It would literally lock onto it and keep it from moving forward unless to jiggled/forced it. NOT good. That alone was enough for me to tell him to nix it. Plus theres the rubbing hoses, weird ratio...
    I had him get a stock drag link- all the PS stuff is coming off.
    GuyW, 1971BB427, dwollam and 3 others like this.
  8. alchemy
    alchemy
    Not only is it a poor design, but an idiot installed it. It’s good he came to you. Might have saved his life.
    RodStRace likes this.
  9. Dreddybear
    Dreddybear
    He yanked it all out and went back to stock and it's a night and day difference. Says it drives great!
