F1 Spindles/brakes To 1940 Drums
Discussion in 'The Hokey Ass Message Board' started by CAL, Mar 17, 2008.
  1. CAL
    CAL
    from Neosho Mo.
    I've got 55 Ford truck frt. brakes/spindles/backing plates on my A. I want to run 17 inch Ford wire wheels. Will 40 ford drums fit? If they won't, can you run 40 drums/backing plates on the f1 spindles? Don't want to run wheel adapters. Any help much appreciated.
  2. alchemy
    alchemy
    55 brakes = 11 inch
    40 brakes = 12 inch
    You're missing an inch.
  3. I tried to run the F1 spindles with 40 brakes and could not come up with the inner bearing.
  4. CharlieLed
    CharlieLed
    Rather than running the 55 F100 backing plates you could go to the F250 which are the same diameter as the finned Buick drums (not sure if the 40 brakes/drums will match the F250).
  5. Flat Ernie
    Flat Ernie
    Tech Editor
  6. 067chevy
    067chevy
    I think the 48-52 F-1 spindels take the same bearings as the 42-48 car spindles
  7. 067chevy
    067chevy
    No I'm wrong. don't know what I was thinking
  8. The outter bearings are the same.
  9. Kato Kings
    Kato Kings
    from Minnesota
    The outside diameter of the f250's are to big and cannot be run with 40 style drums. And the shoes are too wide.
