f100 column shift problems
Discussion in 'The Hokey Ass Message Board' started by BlueFalcon, Mar 24, 2009.
  1. BlueFalcon
    BlueFalcon
    just drove my 63 f100 around for the first time yesterday, but i couldnt shift to 2nd or 3rd. the shifter will move to those positions, but will not let go of the 1st/rev shaft. is there something specific i should be looking for or should i just pull my column out and try to rebuild it?
  2. BlueFalcon
    BlueFalcon
    the hole where the shifter goes into the collar does seem pretty bad. oblonged and mushroomed. does carpenter have a website?
  3. alleyoop
    alleyoop
  4. BlueFalcon
    BlueFalcon
    im pretty sure that tube in the column that is connected to the shifter is f*ed. the little square piece that has the hole in it that the shifter pin goes into looks like is broken off the tube. im just saying screw it and ordering a floor shifter from jegs.
  5. "Whitey Ford" 62 Uni
    from Tampa, FL
    Hey blue...Im on another site which is dedicated to 61-66 ford trucks and I bet if you look on there you could find one from someone rather cheap if intersted...if not yeah dennis carpenter is a good choise.
    On a seperate note your name "Blue Falcon" is a name people use to give others in the Army. If someone called you a Blue Falcon it meant you were a Buddy F*$^er. hahah just had to tell you that but its pretty funny. I still use that name to this day. I call my girl a Blue Falcon if she does something wrong to me.
    also check your kick down linkage. Had the same thing one time when I rebuilt my carb and relaized I screwed that part up when ***embling...anyway hope you get the truck going....
