I need a flywheel dust cover for my 1953 F100 with 4 speed. I'd guess I can modify something that is close. Advice? Thanks!!
It matters which engine (or bellhousing) you are using, as well as which trans. The 4-sp versions have a notch at the rear for the trans. Not clear what's different between V8 and 6-cyl versions. All are obsolete and junkyards are the only source. This just came up over on FTE: http://www.ford-trucks.com/forums/1222924-55-flywheel-dust-cover.html
