F100 Front Clip Swap
Discussion in 'The Hokey Ass Message Board' started by King Karl, Feb 5, 2009.
  1. Mattilac
    Mattilac
  2. Itsa48Ford
    Itsa48Ford
    When installing a Volare clip use a cardboard pattern from the clip and transfer it to the framerails, some minor cleanup is allways neccessary, also move the pattern 1'' to 1-1/2'' forward of the stock axle centerline to better fit in the fender center.
    Also get the clip from a good car, check that the upper arm towers are not bent toward the frame rail,mostly from abused cars!
    I'v installed a few of these units and all work pretty well if you decide to go this way.
  3. I'd contact Gibbon to make sure. It might be that some later '64's used the Twin I Beam which came out officially in 1965 (and is quite different) and they didn't want to have any confusion, so they said "up to '63". I can't think of much difference between a '63 & '64, but who knows?
    JG
    deathrowdave likes this.
  4. skidsteer
    skidsteer
    Take some measurements from a mid-70's Nova or Camaro. Should match right up, I'm not sure about the steering box though.
  5. RickyRodder
    RickyRodder
    So if I have a running driving 93 Dakota w/318 reg. cab shortbed would I pretty much have all the parts to get a 53 F-100 running/driving temporarily until I can get the drivetrain I want?
  6. cfunk0
    cfunk0
    from tx
    :cool:do anybody have pictures of jag front clip being installed on chevy 1951 truck with pic
  7. choke
    choke
    I started doing Chevelle front swaps on 53-56 f-100's in the early 70's. Never had one bit of problems ever. Probably did at least 250 of them. Remember the Truck Stop in Burlingame. He was the first to reproduce 53-56 F-100 parts. I had the back of his shop to do all the fab work. We had at least 3-5 trucks getting conversions in the shop at all times. The trick with the chevelle clip is to **** it inside of the F-100 frame. Then it's a lap weld which is the strongest weld you can produce. Then you box the inside of the frame with a peice that's dimensionaly the same as the F-100 frame. You want to use 64 -early 67 frames because they have staight frame horns because they are pre-cross flow radiator. When you mount the motor you need to raise it up a few inches to line it up with the radiator. The beauty of this swap is if you use a SBC motor is you can use aftermarket hedders from the Chevelle. We use to use a GM early tilt column w/a Tornato u-joint and shaft, but all this is too hard to get nowadays. There's better product on the market now. I still have the fixture to mount the stock F-100 frame horns back on the Chevelle front. It located off of the original rivet holes of the rear spring perch. You can use Chevelle frontends up to 72, but it's a little more work to weld the front horns on. You can do this swap to 55-59 Chevy/GM trucks. the only differrence is you don't have to weld any front frame rails back on. The reason I liked this swap is because the two vehicles were of the same weight. And there was a performance advantage to adapting Camaro front control arms,spindles and disc brakes by moving around some suspension points. But standard Chevelle disk brakes were adequate. If you get the right front end you'll get disc brakes /power steering all in one compatable package. If your going to put a Ford motor in this frame swap you'll need a Bronco oil pan conversion for a small block and a 4 wheel drive oil pan for a big block. I still have the frame dimensions somewhere where to cut the F-100 and Chevy/GM frames. if you need them let me know.
  8. poofus1929
    poofus1929
    from So Cal
    I used to work at a shop that did nothing but install Volare clips in F100's. The engine is always offset to clear the steering box. With a big Caddy engine there might be complications.
  9. So what's the price on the Industrial Ch***is cross member, hup... never mind looks like $675. ( Okay, all together now, DO A SEARCH YAIDIOT! :D) Does he offer an alliance member discount? If I can get my hands on another F-100 that's the route I'll go.
  10. Huntfamily53
    Huntfamily53
    from AZ
  11. THE CHIEF
    THE CHIEF
    from MIAMI
  12. ELpolacko
    ELpolacko
    Website is old, gonna get redone. Current price of a crossmember kit is $589.00 and I have them in stock.
    If I can squeeze a portly 460-514 Lima over the Dakota, a Cad would be easy.
  13. willymakeit
    willymakeit
    Whats wrong with a properly done straight axle ?
  14. King Karl
    King Karl
    from N.C.
    Has anyone heard of using the clip from an LTD? I'm looking at one online that someone already finished, but not sure if they knew what they were doing or not.
  15. ELpolacko
    ELpolacko
    Which one? I have seen a few of the earlier LTD fronts with varying degrees of success. All seemed like a lot more work than the other alternatives.
  16. Larry T
    Larry T
    Didn't Chrisman use a LTD clip in the yellow 56 with the Hemi in it?
    Larry T
  17. Always? My old F-1 had the SBC centered and it cleared the steering box. I think most people who say the motor has to be offset must not run the motor high enough in the engine bay. Personaly I loved the Volare. Brewsir and I installed it, he is a good source of info for these installs, but so is the search function. It rode fine and was low enough for me. LOL.I put LOTS of miles on that truck and Brewsir put like 100k on the Batfink with a Volore clip. That being said on a 57 to 73 F100 I would look into that Crown Vic clip. That article on the Ford truck site is a really good tech piece. The thing with the Volare and now the Crown Vic is there is no high dollar stuff to buy. The clip for either one should be under a couple hundred. Hell if your really good you could get a complete donor car for a couple bills, think auction police cruiser. Nothing against El Polako his setup looks pretty sweet, but I'm a buget minded rodder and if I can get the whole supension for less than a crossmember thats what I'm gonna do.
    Good luck
  18. poofus1929
    poofus1929
    from So Cal
    Your right. The boss always made us stick the motor in pretty low. I think they look better higher in the compartment. SBC always had about a 2 inch offset to the p***enger side. Ford engines were pretty much centered.
  19. Yeah my aircleaner was above the fenders in the hood. I also used stock cast manifolds. One was a center and one a rear dump buut I can't remember wich was wich that might be the difference. I think the drivers was the rear dump. I know it doesn't matter that the motor is offset, it would just bug me every time I looked at it.
  20. trukin55
    trukin55
    I did this front end swap years ago and like many, I have set the project off for awhile and am now back to working on it.
    My question is , What power steering pump do you use or the Volare /SBC combo? Do I have to worry about different PS pressure?
    56 Chevy Truck, Volare clip, Versailles 9" rear
  21. AnimalAin
    AnimalAin
    There are more than a few correct answers to this problem, based on varying criteria. Almost every method has advantages and limitations.
    Keep in mind that if you think you know more than El Polacko about making these trucks sit right, ride well, handle, and stop properly, you are probably wrong.
    As mentioned above, several methods that have been used successfully in the past have been superceded by even more clever techniques. Choose wisely and work carefully; it will almost certainly work out for you.
  22. stuart in mn
    stuart in mn
  23. Itchy
    Itchy
    I am interested in this swap for my 48 F1, but was wondering about the link above. The swap in the link is for a 67. Are the 48 and 67 frame widths the same? And how wide is the trac width of the Crown Vic? Someone asked a few posts back about the width difference, but I dont think it was answered.
  24. ELpolacko
    ELpolacko
    48 frames are 32" wide and from 53 on they are 34" wide.
    Track width on the F1 is 59 1/2" to 60" and the 53-64 trucks are 61" approximately.
    From everything I have seen the CV track is 65" or greater.
    I have done the 61" track under the F1 trucks and it puts the tires awful close to the fenders. If your truck is going to be low, I would recommend keeping the track down to 58 or 59 inches wide.
  25. Itchy
    Itchy
    Thanks for the info. This is my first F1, and still learning what works, and what doesnt.
  26. tailgate
    tailgate
    Hear are some pics of a XJ6/12 Jaguar front in a 60 F100. At a frame width of 34" it is just about at the limit with out some notching, 32" would be a push over. Track width useing 15x6 jag rims is 58".
    Pete
  27. Larry T
    Larry T
    So the complete Jag crossmember bolts in (4 mounting points)? Looks like a real neat setup.
    Larry T
  28. tailgate
    tailgate
    Yeah the whole sub frame mounts at 4 points. Some guys cut the front mounting arms off and wheld it in which would be OK on a rigid frame. Because the F100 frame is designed to have some movement and twist I stayed with the original Jag bolt-in set up. If I want to go lower I can use lower spring or air bags.
    Pete
  29. davis574ord
    davis574ord
    Had one with an mid seventies ltd su frame in it rode nice stopped good also! Torino should work too!
  30. cadillac daddyo
    cadillac daddyo
    from wichita ks
    so why do you have to clip it just wondering
