Technical F100 pitman arm
Discussion in 'Traditional Hot Rods' started by Timothy Murphy, Feb 18, 2024.
  1. Timothy Murphy
    Timothy Murphy
    I’m installing a F100 steering box on a ‘32 ford roadster with the wedge shim. What pitman arm is used? Are there different lengths?
  2. alchemy
    alchemy
    Pretty sure a 1960 is what you want cause it has the tapered hole for a regular tie rod end.
  3. justabeater37
    justabeater37
    I believe 1957-60 F100 are what you are looking for. The F250 and up are longer.
    Timothy Murphy likes this.
  4. 38Chevy454
    38Chevy454
    53-56 have the old ball stud type end for the drag link. 57-60 use a tapered tie rod end style for drag link. 53-60 all have the same pinch bolt at the box end. The steering box is also the same 53-60. It's just the pitman arm drag link end differed.
    dirt t and Timothy Murphy like this.
