Hot Rods F100 Self adjusting brake wires - is this wrong ?
Discussion in 'The Hokey Ass Message Board' started by buickwagon, Mar 28, 2025.
  1. hi all
    Fitting up F100 (1953) front brakes with self adjuster kits (H2540 & H2541)
    The wire cables - right hand side of the car the cable is at the rear but on the other side it seems to want to go to the front ? this doesnt seem right ?
    pic of the left hand front brake ***embly - you can see the wire is on the "front" side
    is this wrong ? / does it matter ?
  2. chicken
    chicken
    from Kansas
    Looking at the pic, the adjuster has an "R" stamped in it and should be an "L" for the left side. Should be on the rear side-never seen one on the front.
    1oldtimer and X-cpe like this.
  3. Oneball
    Oneball
    Should be at the rear.
    From the book: IMG_5304.jpeg IMG_5303.jpeg
  4. V8 Bob
    V8 Bob
    You've got the whole ***embly wrong for a Left Front.
  5. Greg Rogers
    Greg Rogers
    Yes longer shoe is to the rear, does look like everything is backward
  6. Pass The Torch
    Pass The Torch
    I don't ever remember any cable / wire on any of my F100 brakes.
  7. Self-adjusters started in 65 but will fit clear back to 53. It's a common upgrade. Where is the adjuster access hole in the backing plate? You want to make sure it's in alignment with the adjuster wheel.
  8. 302GMC
    302GMC
    from Idaho
    In the '60s - '70s, dozens of customers were paying us to eliminate all that stuff "so their shoes would last" ...
    down-the-road, AVater and F-ONE like this.
  9. bobss396
    bobss396
    That cable looks a bit on the loose side.. :oops:
    down-the-road and X-cpe like this.
  10. X-cpe
    X-cpe
    It is a camera angle optical illusion. The brake shoes are oriented correctly on the backing plate. Look at where the friction material ends on both ends of each brake shoe.
  11. 55 Ford Gasser
    55 Ford Gasser
    When you change to self adjusters, the access hole will not always line up. Did this to my '50 Ford Sedan. Also, make sure the piece that cable goes around is in properly. If it does not stay in hole, the cable will be loose.
    down-the-road, Pist-n-Broke and X-cpe like this.
  12. Correct. The way I posted that question was so OP would look and see that he needs to make a new slot in correct place. There is also a left hand and right hand threaded adjuster. They need to be on the proper side.
  13. lostone
    lostone
    from kansas
    I would bet the adjuster is wrong too.
    From what I can see the cable is loose because the adjusting arm is against the adjuster and can't turn the star because it's already tight and trying to tighten it even more.
    The adjusting arm should be down and the star wheel should be able to turn with it not against it as it looks now. So to be sure you should be able to grab the star wheel and rotate the top of it out towards you and it should un-screw but I bet it gets tighter or shortens it.
    down-the-road likes this.
  14. bobss396
    bobss396
    All self adjuster hardware for Fords are the same, only the cable length is different for the drum sizes.
    Something is definitely off in that first picture. Maybe it is the guide-hole that is just off enough?
  15. 50chevytx
    50chevytx
    Full shoe always goes to the rear.
  16. All sorted (new slots in the backing plate) Thanks All
  17. Mr48chev
    Well you can lead them to water but some times they don't understand how to drink.
    The ALL WRONG part is that you have all the right hand side self adjuster linkage on the left hand side of the car. There is a specific left and right with the Ford adjuster pieces. Note the afore mentioned R on the adjuster lever.
    The kit numbers are right for 11 inch brakes without seeing it with the hub off I can't tell. Screenshot (691).png Screenshot (689).png
