F100 to camaro Clip
Discussion in 'The Hokey Ass Message Board' started by xtremer-pxl, Nov 9, 2009.
  1. xtremer-pxl
    xtremer-pxl
    Hey gents.
    I have a 64 ford straight axle and Ive searched around the forum and found several guys claim to have the done the camaro clip swap. but they didn't really offer any information about it. I was kind of looking for information, suggestions and maybe a few frame pictures.
    thanks!
  2. xtremer-pxl
    xtremer-pxl
    I did some measuring and looks like the two clips are really close. should be an easy swap.
  3. DonMan
    DonMan
    By far, the easiest swap is to use the complete front suspension / crossmember from a 2005 - up Crown Vic. It is practically a bolt-in. You don`t have to cut your frame.
    Do a Google search, you`ll find info.
  4. chaddilac
    chaddilac
    Here's a 60 with a camaro clip, I talked to the guy that built it, he said it was a little too wide for the frontend and they widened the fender flares on it. I couldn't get much inside the hood area, but you can see where he placed it on the frame. They told me the Nova front clip was better cause it was a little narrower.
  5. xtremer-pxl
    xtremer-pxl
    Will the crown vic frame layout on bags?
  6. rusted_nut
    rusted_nut
    from Arkansas
    You have to use zero offset wheels with the crown vic front end
  7. DonMan
    DonMan
    Not sure.
    Go to www.ford-trucks.com . Go to FORUMS and check out the 61-66 section. Do a search. The info you`re looking for is there.
  8. hotrod-Linkin
    hotrod-Linkin
    first gen camaro,nova clips are narrower. go to fatman fabrication and look at the front stub kit for fords. it allows you to use mustang II stuff and the you can bag it.
