f2 ford emergency brake assembly
Discussion in 'The Hokey Ass Message Board' started by jnunez1955, Jul 30, 2010.
  1. jnunez1955
    jnunez1955
    im trying to restore an old f2 ford pick up truck 1949...the original e brake was on the drive and ******....but the car now has a chevy 265 and a muncie 4 sp.
    is there anyway to adapt e brake brackets to the original rear brake backing plates? if so, where can i buy the kit?
  2. bobj49f2
    bobj49f2
    Ford didn't mount the parking brake to the rear of the ****** until 1953 on the F-2. Before that the brake was activated by the lever mounted under the dash, on the left. The original set up had the cables running to the two back wheels. There's a "U" type clamp that holds the cables to the backing plates. If you have the original rear backing plates look at the front half, at about the 4:00 position. There should be an opening with two 5/16" holes, that's where the cable went through. I don't know anyone who sells replacements.
