Fab tool question?
Discussion in 'The Hokey Ass Message Board' started by madmak95, Oct 23, 2009.
  1. madmak95
    madmak95
    Im cutting up some box tubeing for a frame , and am Zing the rear. I make the cuts at 221/2 degrees , makeing two 45s for the Z. My question is does anyone make a speed/T square that is set on 221/2 degress insteed of the 45 and 90s? I google but could not find any.
  2. squirrel
    probably won't find one like that...but there are adjustable "squares" I think called protractors or something.
  3. RugBlaster
    RugBlaster
    Just cut some s**** tubing 11 degees each, flip one over, check it with a standard and weld them together....make your own tool.
    When your finished with it, they make a good tool to hit your mother-in-law with if she gets mouthy.
  4. bowtiemyk
    bowtiemyk
    harbor frieght has a steel protractor & some other angle finders I find useful. You might try your local Sears also
  5. Unkl Ian
    Unkl Ian
    I've seen them for wood working, just as easy to make your own.
    Or use an adjustable protractor.
  6. remi
    remi
    from nb, canada
  7. [​IMG]
    adjustable speed square used by siding installers and carpenters
  8. realkustom51
    realkustom51
    At the Vaughn Bros. shop, I have to maintain a qty of protractors. From 48" to 5". The square head 18" is a must for radius larger than 3". The 48" is a sheet rock protractor and works great for spanning gaps in a ch***is that are not finished or tacked.
  9. 61bone
    61bone
    An adjustable try square is what you need for what you ask. I ***ume that you are doing the cuts with something other than a chop saw which can be adjusted to the required 22 1/2 dg. Make a guide out of a couple pieces of angle iron welded so one side fits against the iron so it can be clamped there. The other piece welded so the upright side can be used as a guide for the torch. If you select the right width angle, the tip nut can be rested on the top, holding the right cutting distance(1/8" from the end of the cones).For a plasma cutter, us a 1/4"x 1" flatstrap for the cutting guide. Most plasma rigs don't need a dragcup if using less than 40 amps, the tip can be drug directly on the metal. Either way, make a test cut, then measure the distance from the guide to the close edge of the kerf. This is your offset. Always set your guide to the offset on the save side of the line. Also measure the width of the kerf, it has to be added to the length of the drop. For instance, if your kerf width is 1/8" and your offset is 5/16", ( my cutter) set up as follows. If you need a piece 5' long (drop) and a piece for the z 11" long (save) mark your line at 5' 1/8" With the angle going longer on the piece. Set up your guide 5/16" back from the line on the save side and make the cuts. move down 11", again with the guide on the save side,make the cuts and voila, pieces the right length after t******* the second drop to length. Hope this helps.
  10. RugBlaster
    RugBlaster
    Ok, Ok,........first you build this huge wooden badger...
