fabbing instrument panel from brass
Discussion in 'The Hokey Ass Message Board' started by draggin breath, Dec 20, 2007.
  1. draggin breath
    draggin breath
    While I owned a boneyard i saved br*** door scuff plates from the junk.I want to do an instrument panel that will be plated and thought this br*** would be easy to work with and get chromed. Any pitfalls to be aware of?
  2. raven
    raven
    I just finished a br*** dash insert for my roadster. We engine-turned it and then shot clear over it. Looks great. Make sure you seal it some way.
    r
  3. gas pumper
    gas pumper
    I made some piecses out of br*** plate that was chrome plated. Found it in the junk. I actually think it was a mirror for a restroom. I thought it was shined stainless until I cut it and found the br*** under the shinny silver.
    So another source for cool ****, Industrial restroom mirrors:D
    Frank
  4. mistoo
    mistoo
    from Sweden
    raven61 I would love to see a photo of that dash. I have thought about doing the same thing
  5. Unkl Ian
    Unkl Ian
    Should be able to Chrome over Br*** no problem.Just spend the time
    to polish the Br*** to perfection,or every little defect will show in the Chrome.
  6. COS
    COS
    from KCMO
    Here are some pics of Ravens' Dash....:)
    P.S. R I found your pics that we have been looking for!!:rolleyes:
  7. Br*** scratches easy while you're working with it. Like if you use a hole saw to cut the holes for the gauges, you'll wind up with a bunch of s****es around the hole from the curly cues dragging around in circles. Br*** clogs up sandpaper fast too, so it takes longer to smooth it up.
    I made a dash insert for my '31 Plymouth out of 1/8" br*** plate and was thinking I was going to have it plated, but when I was getting close to a polished surface, I was using I think a 3M "surface conditioning disk" and it was leaving some pretty cool looking sparkly patterns, sort of like a variation on engine turning but looking more like tiger stripes. I made a bunch of vertical p***es overlapping on each p*** and I liked the look, so I sprayed it with clear acrylic and it's still looking pretty good about 8 years later. The br*** isn't quite as shiny as it used to be. Sorry, but I don't have a picture of it.
    When I made my dash, I silver-soldered (silver-brazed) some bolts to the backside of it and used nuts from the backside to secure it to the dash -- that made it so I didn't have to have any visible fasteners on the front side. Silver solder sticks really well to br***, and it's pretty strong.
  8. Hans
    Hans
    Raven...that dash is sooo, sooo, sooo ****in cool.
    I really like it.
  9. GTS225
    GTS225
    Raven......looking at the pics, and noticed a difference in the appearance of that insert. The surround for the smaller guages has a different look to it compared to the larger surround. It appears that you did a directional change in the overlap pattern, but I'm not sure.
    Care to share the "secret", or is it just an optical delusion?
    Roger
  10. Unkl Ian
    Unkl Ian
    Looks like two pieces.
