Technical fabricating steering wheel rim
Discussion in 'The Hokey Ass Message Board' started by tomic, May 14, 2017.
  1. tomic
    tomic
    hey, i've got a question for the gang... i'm looking for a suitable resin or something like it to create this particular idea i have for a steering wheel rim.
    it's for my Rambler Roadster. i'm running the original '61 steering wheel, it's 18" diameter, i like it. the box is made by Gemmer and has a weird spline, and i actually like the wheel (pic below isn't very flattering). i don't wanna replace it.
    what i want to do is build up the diameter of the rim from it's currently scrawny 3/4" diameter (with a groove, and typical finger bumps, and the clearance for where the old bowtie style horn ring was) to about 1.25 -- 1.5 inches diameter. i have a plan, man, but need help with some chemistry.
    my idea for buildup is to grind the finger bumps off, and round out the groove and horn ring clearances in the rim with epoxy and half-round filler to get the diameter consistent, then wrap it with woven fiberglas tape, something like, if not exactly, 1" woven black fiberglas exhaust wrap. with the rim built out to more or less round, the fiberglas fabric tape, edge to edge flat, will bring the diameter up to what i want.
    the catch is that it needs a binder and coating. the trick is a resin that has sufficient pot time to wind the rim (though i could wet sections as i wrap, and pause for it to kick), but, as critical, when it's cured it is the proper "durometer" and non-sticky/firm surface. traditional Hurst type transmission shifter balls have the right kinda hard gumminess.
    not sure if fiberglas polyester resin is right. i'm gonna rig up a test for that. can anyone think of a resin, or epoxy, that might work? it's gotta be thin enough to saturate the fabric without bubbles, but cure hard enough. i ***ume the surface will be AFU from the wrapping work and i'll sand and recoat the outside.
    i'm very good at fabricating crazy **** from scratch. for this i'd jig the wheel hub up/rim down rigidly to facilitate easy/fast wrapping (and the inevitable drippy mess).
    anyone done anything like this?
    sorry, the pic, taken at night, makes everything look warped and bent. it's not.
  2. RMR&C
    RMR&C
    from NW Montana
    Years ago there was a thread on here where a guy made a custom banjo wheel. He made a form/mold from MDF and basically cast the rim using fibergl*** filler. Turned out really nice.
    Sorry I don't have a link....maybe a search would find it.
  3. David Gersic
    David Gersic
    from DeKalb, IL
    Unless the wrapping fabric is stretchy, you're going to have trouble getting it edge to edge and flat. If you can get past that, is there a long pot time resin or a retarder you could use to get the time to wrap it?
    Casting the whole thing might be easier. I'm sure there's a resin that'd work. I use Smooth On resins from Eagre Polymers in Chicago for casting parts, they've got some good advice / tech guys, maybe give them a call and see what they recommend for what you're trying to do.
  4. Dan Timberlake
    Dan Timberlake
    epoxy resin bonds WAY better than regular old polyester "fibergl***" resin. Polyester resin barely bonds to itself if repairs or additions must be made after the original monolithic fabrication. That is part of the reason it is recommended for bonding repairs for metal and fibergl*** by GM back in 1955.
    http://chevy.oldcarmanualproject.com/booklets/55smri/index.html
  5. 4woody
    4woody
  6. dreracecar
    dreracecar
    from so-cal
    Replace the outer ring with a larger dia tubing closer to your preference and just do a single layer wrap instead of building up with resin/wrap
    Hnstray likes this.
  7. Hnstray
    Hnstray
    from Quincy, IL
    ^^^^^^^^^THIS!!
    I seem to recall seeing circular tubing suitable for this for sale somewhere. An internet search should turn something up.
    Ray
  8. rusty rocket
    rusty rocket
    Lets see the rest of the car.
  9. tomic
    tomic
    yeah... inside vs. outside radii is the "obvious" problem. i've seen wheels wrapped with cord, that partially deals with the difference.
    this might just be a stupid project (but i suppose they all are to some degree or they wouldn't be worth bothering with). i hadn't even considered casting, but i'll follow all the links here and check out different approaches. nor had i considered that there might be premade tube hoops for this task...
    i don't want a small diameter wheel. i like 18", it suits the ****pit. 16" might be tolerable, but they all look like some TV version of "sporty".
    maybe i should bring calipers to the Pomona swap meet and look at other-brand wheels to see if i can adapt something else. i don't mind work, but some tasks turn into make-work all too easily.
  10. tomic
    tomic
    ok...
  11. tomic
    tomic
    (funny how good technique never ages out...)
    reminds me that i've been thinking of this wrong -- co****, open-weave gl*** and epoxy resin should work fine and solve two problems at once -- the radii problem and pot life. that open weave stuff stretches, more or less, in that it shifts and distorts especially in narrow cuts. that will solve the radii problem. relatively short strips will sole the pot-life problem in that i can do many small batches (annoying, but straightforward).
    i guess i'd been ***uming that with something decent looking to begin with, eg. the exhaust wrap type stuff, with it's nicely bound edges, that a clear hard resin over that would be a good final finish. gl*** and epoxy would be rough and need finishing, but BFD, i can do that and epoxy paint it.
    that's a lot for that, it got me to rethink some unquestioned ***umptions.
  12. BJR
    BJR
    Bet you are sorry you asked now.
    Bandit Billy and fourspeedwagon like this.
  13. tomic
    tomic
  14. tomic
    tomic
    lol. it's a shiny-side-down car. it gets driven hard and long. just had the ancient Nashcan six built, custom forged pistons, the guy managed to get some overlap out of a cam regrind (no cam blanks for this motor, even 50 yrs ago), crankshaft spark, straight and balanced bottom end, and Modern Drivelines close ratio T5 and narrowed/regeared mustang rear. disks all around, my own rear suspension design, 2250 lbs curb weight. made for rally and long distance. even does dirt roads.
  15. rusty rocket
    rusty rocket
    aahhhh maybe!
    Bandit Billy likes this.
  16. jailbar joe
    jailbar joe
  17. jailbar joe
    jailbar joe
    there was a thread on the hamb about 12 months or more ago and it was called
    ..."cutting down my banjo wheel"... i'm pretty sure that is the info you seek
  18. There was a post on here (and I'll be damned if I can find it again) where a guy built or rebuilt a wheel using Corian or some similar synthetic countertop material. He got two pieces of material, used a router to form the two halves, then glued them over the wheel rim using the special matching epoxy. The wheel rim was OEM-type 1/2" steel rod. The method was very similar to the above 'banjo' thread, but no casting was involved. His turned out looking great....
    I plan to try this to rebuild my OEM Desoto wheel.
  19. Casual 6
    Casual 6
    from Great NW
    It's this one.
  20. I would think looking for a wheel the right size and condition, then mating it to your spokes. Then you just have to make the joints look good. I'm lazy though..
  21. gimpyshotrods
    gimpyshotrods
  22. squirrel
  23. FlatheadWard
    FlatheadWard
