1952-59 Ford Factory fuel gauge hook up
Discussion in 'Off Topic Hot Rods & Customs' started by Baggs, Sep 2, 2011.
  1. Baggs
    Baggs
    Hey all, I'm about to run a voltage reducer to my fuel gauge and I need to know hich post on the back of the gauge gets the power feed and which is ground?? I'm currently in the garage waiting anxiously for the answer haha aphoto would be sweet if possible thanks guys
  2. Retro Jim
    Retro Jim
    Please don't take this the wrong way , but do you own a test light ? Sometimes you can find the + & - marks on the back of the gauge as well . That will be the easiest way to know which is the positive . You could also use it at the sending unit as well .
    just a thought .
    Jim
  3. Baggs
    Baggs
    Well I have the gauges out of the car along with the sender. In the process of installing the new wire harness and dont have any power in the car yet, so I can't really use a test light. No offense taken, I wasnt clear on the situation
  4. evorandyp
    evorandyp
    Looking at my wiring diagram it looks like the power would go to the "F" side of the gage and the sender would hook up to the "E" side.
  5. Retro Jim
    Retro Jim
    I didn't know you were starting from scratch ! Yea a test light won't do you any good right now ! I thought you were just installing the reducer on a simple 12v conversion . The instructions should show you but I don't know what wiring harness you are using .
    Jim
  6. Baggs
    Baggs
    Using rebel wire. Hearing the power goes to the f side makes complete sense
