Faded car trailer
Discussion in 'The Hokey Ass Message Board' started by EDPACECAR, May 8, 2010.
  1. EDPACECAR
    EDPACECAR
    Anyone restore a faded enclosed car trailer. It was black but now really dull.
    If so what did you use to bring the paint back?
    Would hate to use something that would remove the paint.
  2. hotrod1940
    hotrod1940
    Not enough info.
    Faded paint?
    Faded anodized aluminum?
    Faded enamel?
    Faded Lacquer?
    Buffing wheel and polishing compound, probably.
  3. flamed34
    flamed34
    Don't bother...it's an ENCLOSED car TRAILER. It should be sitting in the driveway while you DRIVE your car.
  4. indyjps
    indyjps
    Id say paint it, if youre wanting to restore the black paint get a good buffer and go to work, but remember the paint they used probably wasnt that good to begin with - industrial grade not auto grade.
    Perfect use for that ebay/summit brand paint $40 a gallon
  5. redlinetoys
    redlinetoys
    from Midwest
    Those sheets of metal on that trailer are likely pre-coated stock. In other words, they roll-coat the metal with coating prior to rolling it back up and then later use it as pre-coated stock.
    This process applies a VERY THIN coating of paint which will likely buff through if you try to machine buff it.
    Talk with a couple of quality body shops in your area and have them look at it. A picture is worth a thousand words, but I would suggest having this ****yzed by professionals locally.
  6. flynbrian48
    flynbrian48
    It is considered socially unacceptable to use a car trailer, particularly an enclosed one for any reason other than a dire emergency. If needed, the trailer MUST be in such dilapidated and ill kept appearance so as to inform all that you don't use it, don't care about it, and that it is stored outside in back of a shed untill needed. I\
    Also, said trailer MUST have been lent to aquantances (who only call you to ask to borrow it) who then cut the wiring plug off to fit their vehicles trailer harness, bend the ramps, lose winch straps, cut safety chains, and/or bend the tongue while backing up because they don't know how to back up a trailer.
    Hope this helps.
    Can I borrow your trailer?
    Brian
  7. Kenneth S
    Kenneth S
    They use cheap paint, and apply it very thin. Repaint it with good automotive paint.
  8. FastAndLoose
    FastAndLoose
    from Warren, PA
    It's likely powdercoat and in the 15 years I've been involved in dirt track racing, I've only seen one semi-successful cleanup of a chalked-up trailer. If the trailer is still in good shape structurally, you're probably better of to have it reskinned. What brand trailer is it? Riveted or bonded sheet?
  9. 666Irish
    666Irish
    Put some faux patina and phony rust on it. Call it a 'rat trailer'.
  10. Truckedup
    Truckedup
    Now this should be the law of the land.Exception,race cars....
  11. 50Delux
    50Delux
    from Michigan
    Funny this comes up.Yesterday we had a guy clean up the enclosed (for one of those cars that only get driving a 1/4 mile at a time) at our shop.He wheeled it out and waxed it.Brought the shine back to it and only charged $100. for a 28'.
  12. sawzall
    sawzall
    ed your trailer must be black.. or a dark color..
    as the one I just got (is white) and doesnt seem too bad..
    how about a "wrap?" sorta like the cup guys do with the roundy round cars?
  13. little skeet
    little skeet
    from huston
    It is no different than a motorhome. After a good wash job, use a quality brand name liquid cleaner first, then put on a wax job. You can try a small area first to see the results and if you like it.
    Ignore the ones that tell you how to live your life and how to use your trailer. Some of us like to take care of things we own and not drag around ****py looking equipment.
    "Wasn't anybody there except me and Little *****"
  14. Buffed mine with a good cleaner wax.
  15. LANCE-SPEED
    LANCE-SPEED
    i thought you found my car trailer?
  16. JOECOOL
    JOECOOL
    Enclosed car trailers are like ugly women, as long as they make you happy ,screw everybody else !!
  17. 55 dude
    55 dude
    make it too nice and it's sure to get stolen! leave it ugly.
  18. 49ratfink
    49ratfink
    faded black? paint the wheels red, wide whites, ad some skullz and iron crossez and yer in with the cool guys.
  19. Try a good quality car polish. You might be surprised how quickly it comes to life. Like stated above, the coating on these trailers is fairly thin so I'd hesitate to start with anything too aggressive, like a buffer and rubbing compound. Do a hand application first to test the paint. Black and red probably 'chalk up' worse than white or silver, but they'll all do it eventually if you don't take care of them.
  20. Bull
    Bull
    You could try our Finish Cut or Turbo Cut compound by hand -- so as not to buff through the paint.
    Followed up by our Shine Master Polish.
    We recently tried this process on ***us Deuce 4-door that had been in barn storage for 40 years and it brought back the dull, faded finish surprisingly well.
  21. Smokin Joe
    Smokin Joe
    Where's Germ when you really need him...
  22. EDPACECAR
    EDPACECAR
    It a Haulmark skin is screwed on. Had it since 1997 and only used it a few times. Had just been sitting in the sun. And fading away. Thanks
