fainting flatty heads
Discussion in 'The Hokey Ass Message Board' started by sedan_dad, Mar 25, 2004.
  1. sedan_dad
    sedan_dad
    I'd like to paint in between the fins on my Offy heads.Is this a waste of time.Will it burn off?
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    I never have seen a head faint before [​IMG]
    But have painted the heads on my flatty. They do hold paint well. Just be sure to prep it correctly.
  3. Iceberg
    Iceberg
    If you don't prep them well the paint will fleck off and cause you to faint. Which would be technically fainting (on) flatty heads!
  4. rough em up a little with some 600 grit. Then prime 'em with zincchromate primer. Then the paint will stick forever(or a little less).
  5. racer5c
    racer5c
    It will hold heat in don't do it
  6. tommy
    tommy
    Wash them down to get them completly clean just like painting a fender. I use Cherry flavored Chap stick to mask off the top of the fins (easier than tapeing) Tape the big areas and shoot. The Olds and Pontiac heads burn the paint on the center exhaust points but, I've never had a problem with flatheads if they are prepared right. This head was painted 7 years ago.
