Fairlane shuts off when reching operating temp
Discussion in 'The Hokey Ass Message Board' started by stuckonda101, May 19, 2012.
  1. stuckonda101
    stuckonda101
    from SFV, CA
    Hey guys, any ideas on what may cause this?
    Fresh 289 engine, new distributor/cap/rotor/coil/wires/ igntion switch
    rebuilt carb (tested), new fuel lines gas tank clean (was driven daily before engine swap)
    the car will start right up.... idle until its warm then shut off, then it becomes increasingly difficult to start.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    IF you are running points it could be a possible bad condenser,I had a new one that was defective do that, also check the voltage at the ballast resistor when it's cold and when it cuts off.
  3. stuckonda101
    stuckonda101
    from SFV, CA
    replaced the points and condenser also, no luck... also i dont have a ballast resistor, i have a resistor wire which is also new.
  4. Smiliesafari
    Smiliesafari
    Heat causing the coil to break down.
  5. stuckonda101
    stuckonda101
    from SFV, CA
    The coil is new, its from oreillys... Should I get one of em fancy accel coils? I don't see it getting too hot, its above the intake.manifold.... Whatta ya think?
  6. Willy301
    Willy301
    X2....new coil or not, it could easily be a bad one...or you could be vapor locking...are the fuel lines away from the exhaust? Get the 1" phenolic spacer for the carb to get it up off the intake, that will help too...
  7. Willy301
    Willy301
    Coils work off resistance....resistance makes its own heat. You don't need a fancy coil, just a good one.
    I guess I shouldn't say work off of resistance, but a certain amount is inherent to them. A short causes more which equals more heat. More heat causes it to short completely. It would restart normally after it cools off.
  8. stuckonda101
    stuckonda101
    from SFV, CA
    I'll try a new coil, won't hurt. Also I have a spacer on the carb. Fuel lines look to be clear from exhaust
  9. Blk210
    Blk210
    from New Market
    Does it fire right up when cold? if so check the coil, if it is difficult or pops at all check the dwell and the cam gear if you reused the distributor, i had a mustang i did for a guy which did the same thing, he tried to cut corners by reusing the distributor but the points were bad so we had to replace them and set the dwell but then he didnt realize what cam was in the motor he brought us and it had chewed up the cam gear making it jump timing and shut off when warm.
  10. stuckonda101
    stuckonda101
    from SFV, CA
    It does fire.right up, I've tried the old and new distributors and the results are the same. as luck would have it I got a 15 dollar pep boys gift card in the mail so I'm gonna buy a new coil with that and see what happens
  11. 325w
    325w
    Leave the gas cap off for a few minutes. See if it was creating a vac in the tank
  12. godswill
    godswill
    from san jose
    line loc in fuel lines maybe. its usually after the fuel pump and near a radiator hose
  13. tommyd
    tommyd
    from South Indy
    Good info here^^^^^
  14. Dan Timberlake
    Dan Timberlake
    The poor abused rotor tiller started and ran OK earlier this year. Loaned it to a friend a few weeks back and they brought it back. Went to use it this morning, and it was running rough. I Filled tank, and just happened to start it with the gas cap off. The MOMENT the gas cap sat tight against the tank the motor (now with choke off) shut off. Tried it 3 or 4 times with the same shut down result. Dis***embled the cap as far as it would go and cleaned things up, but there is no visible vent hole. Still shut right down. Drilled a 1/16 hole thru a likely section of the cap and it runs fine. I would have done a fuel pressure and delivery test, but the carb is integral with the fuel tank.
  15. 40FordGuy
    40FordGuy
    Ditto a bad coil..... "New" ,..."only means it's shiney..." Same for a condenser........
    4TTRUK
  16. Dan Timberlake
    Dan Timberlake
    If the idle mix is set pretty rich (or float level is high or needle seat seeps, or ****) engines start and run cold OK. When the engine is warm rough running and stalling can be expected.
    I'd do a few tests to ID if I have an ignition or a fuel problem (or very long shot, both).
    Plenty to do before replacing any parts "just because."
    http://www.secondchancegarage.com/public/1953-1960-trouble-guide.cfm
  17. stuckonda101
    stuckonda101
    from SFV, CA
    i changed the carb with a 2 barrel and an adapter, still have the same problem, so its definetly ignition. bought a new coil but the battery is losing power, so im gonna charge it and try it then.... the car gets gas regardless so its not vapor lock, it will shut off even as i spray carb cleaner on it...
  18. stuckonda101
    stuckonda101
    from SFV, CA
    ran the new coil, same problem
  19. GassersGarage
    GassersGarage
    Mine was a bad resistor wire.
  20. tedley
    tedley
    from canada
    Check your voltage at coil . Should be what, 9 volts?
  21. stuckonda101
    stuckonda101
    from SFV, CA
    can i replace the wire with a resistor? getting under the dash is a pita, lol. voltage was 7 volts until it shut off. i couldnt test after because im working on it by myself
  22. 40FordGuy
    40FordGuy
    Does it "shut off" abruptly,...as if you turned the ign switch "off",..or does it act as if you were running out of gas ? An abrupt shutdown means ignition...the other indicates a fuel issue.
    You can run a resistor,...be sure to run a new wire from the replacement resistor, to the coil. You don't need to double the resistance.
    4TTRUK
  23. stuckonda101
    stuckonda101
    from SFV, CA
    yes it shuts off abruptly. Im looking at finding a resistor i can run but having a hard time finding the specs off of one, that way i can get rid of the resistor wire and run the ballast resistor.
  24. stuckonda101
    stuckonda101
    from SFV, CA
    oh and the bad part is that on my fairlane the resistor wire is under the dash so its gonna bust my back pulling it out, lol
  25. bobwop
    bobwop
    from Arley, AL
    some sort of strange wiring issue?
    electric fan?
  26. tedley
    tedley
    from canada
    Are you sure you got a points coil and not a electronic ignition coil. Makes a diffence. Electronic coil is like a 3 ohm and points 6 ohm. I think that's the way it goes.Petronics will run on a points coil.
    7 volts with a voltmeter on the coil? with the motor not running but just with key on? Seems abit low. It will run till you rev it and might break up but shouldn't stall.
  27. stuckonda101
    stuckonda101
    from SFV, CA
    its a points coil. fomoco manual says to replace wire if under 6.6... im having a hard time finding the wire since its not shielded like i thought it to be... im starting to be very frustrated by this car..
  28. stuckonda101
    stuckonda101
    from SFV, CA
    Actually fomoco manual says to replace if ABOVE 6.6...
  29. I noticed in one of your posts that the battery is losing power. Why? from cranking?, or is it not charging?
  30. stuckonda101
    stuckonda101
    from SFV, CA
    From cranking...
