Falcon x2
Discussion in 'The Hokey Ass Message Board' started by lotus, Feb 23, 2009.
  1. Falconred
    Falconred
    The pattern should be:
    R 1 3 OR _1 3
    |_ | / | | | / |
    2/ 4 R 2/ 4
    There are replacement shifters available just like the ford shifter or they make shift handles that bolt to hurst shifters that look just like the Ford handle. I've got a standard Hurst lever in mine as most of us had to change them back then for any serious use anyway. I broke my stock handle one day just pulling second gear hard.
  2. Yeh, your shifter is a blend of OEM, Hurst, Foxcraft, coat hangers, old bicycles.
    Borg Warner T-10 four speed. Mustang shifter WON'T work. Must be for a Falcon, possibly Comet.
  3. Falconred
    Falconred
    I like your car, the stance if just right, straight axle but not so nose high as to look funny. Looks like you have another good one in the yellow car. I am on my third '65 Falcon now and have had two '64 Comets. I hope to start soon on bringing mine back as a B or C /FX clone. I am going old school with it and trying to make it as close to they way they were back then.
  4. lotus
    lotus
    from Taft, CA
    Don't forget the nail being used in the shifter as the pull lever! haha
    If stuff was in upside down would it cause the shift pattern where R is by 2nd on the bottom to be on the top?
  5. hotroddon
    hotroddon
    All these little patterns are harder to follow than these pics. One on the left is early Mustang/Cougar. One on the right is Fairlane/Falcon. Regardless of whether it is a T10 or a Dagenham box.
    [​IMG][​IMG]
    this is the early 3 speed shifter
    this is a T10 4 speed
  6. Falconred
    Falconred
    They probably didn't have to change the reverse lever for clearance as it is in a different area of the tunnel.
    The photos that hotroddon posted are a good way of showing what we were talking about. The pattern I tried to show slipped when posted, not sure why. Looks like you have the correct transmission as it has the shifter mount in the correct location and the short looking tailshaft housing.
  7. lotus
    lotus
    from Taft, CA
    I found a picture of one with the arms going up so now I know what you guys are talking about being upside down.
    thanks again for all the information! It helps a ton.
  8. Muttley
    Muttley
    Unbolt all that ****, throw it in the nearest dumpster and order a Hurst Compe***ion Plus. I have one in my '65 Comet and it rules.
  9. chappys4life
    chappys4life
    from Austin, TX
    nice car always wanted a 64 or 65 with a 302 and thumpy cam
  10. glendale
    glendale
    sweet car man. i want one real bad for a daily. you can do the shelby drop also. it lowers the front by like an inch and it's free. you just redrill the shock towers for the upper a-arms. i have the drill guide and the drill bit. if you want to borrow it shoot me a p.m.
  11. lotus
    lotus
    from Taft, CA
    well i pulled the carpet today and the floors are not that bad. Should be fairly easy to fix. The part that concerns me is not rust through but the area on both sides in the area where the rear of the buckets bolt up to being broke. I can fix it easy enough but I want to find out what caused it.
    Most of the rust is surface and some of it is just that horse hair ****...
    The two broken areas.
    The worst of the rust...
  12. The cracking is from the car flexing from wheel hopping, drag racing.
  13. Kustomkarma
    Kustomkarma
    Looks a lot like my '64 Comet's floor pan. Mine's pretty solid but has rust in the torque boxes. :(
