Features Falcons done right?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Nov 20, 2005.
  1. ybu22z
    ybu22z
    Thanks for that GearHeadSoul. That is an impressive bit of work.
  2. Ghostcruiser
    Ghostcruiser
    from NE Florida
    Rob,
    Take it from another Rob who tried the Geo Metro route (my opinion): Don't do it. Despite what some folks say, it will never be what you want, it will always feel 'spongy', and it will always make you feel as if you're about to slide into the ***-end of the car in front of you at a sudden stop. Driving in the rain is a death-wish. Plus, the proportioning valve setup is a nightmare to dial-in correctly. I tried it for 6 months on my V-8 Falcon wagon, hated it, and replaced all my brakes with a manual system, using a dual-bowl m/c from a '67 'stang, a stock Grenada prop valve with 11" disc front and drum rear.
    I love driving it now! :)
    Rob
  3. INTRUDER
    INTRUDER
    from NW Indiana
    The early 70's Maverick dual pot manual m/c will work.
    Bolts right up to the factory holes. I just can't remember which rod to use.
    Or if you have to modify the Maverick rod.
    With the manual and drum brakes you do not need a proportional valve , with front disc brakes you do.
  4. Ghostcruiser
    Ghostcruiser
    from NE Florida
    All you have to do is cut the "****on" off the rod they supply with the m/c....round the tip, and it'll be the same as the stock Falcon rod....Yep, the prop valve is a must for disc up front; but, I'm using a drum/drum m/c and it works fine....;)
    Rob
  5. chromedaddyo
    chromedaddyo
    from Ohio
    "Falconstein" 63 1/2
    351 W, C4 ,4.56
    <!-- / message --><!-- sig -->
  6. kustomdlux
    kustomdlux
    YES....YES...and YES!
  7. MUNCIE
    MUNCIE
    from Houston
    Love it :cool:
  8. American Hellbilly
    American Hellbilly
    from Seymour,IN
  9. vw505
    vw505
    from Lemoore,CA
  10. Bill Poole
    Bill Poole
    Falconators
    Great thread...I've been following it for awhile and thought I'd post a couple shots of my 61 tudor.
  11. MUNCIE
    MUNCIE
    from Houston
    Well I ordered my replacement floors from AutoKrafters this past Firday and was anxious to get started on cutting out my old floors.Low and behold got an e-mail today stating that these items are on back order and the manufacturer will be making them in about 45-60 days :0 Man I was hoping to get them in a week or so.Might have to move on to the trunk now and start my metal work there and work my way back up.
    On another note might be getting a c4 auto this week and did a little reading on here and some people have said that I may need to do a little banging to make it fit in the trans tunnell.Anyone ever have to do that? Also will be thinking about running a 3.73 gear set up in the rear (it's out of a 67 mustang the beefy one with more ribs on the the outer casing).Any ideas on what stall converter to use along with a shift kit?
  12. Ghostcruiser
    Ghostcruiser
    from NE Florida
    I had to do more than 'bang' my trans tunnel...the C4 sits a bit higher, so I had to cut a rectangular hole for the shifter mount, and the top of the ******...:)
    Rob
  13. darkle
    darkle
    from fresno, CA
    nothing spectacular like others on this forum but here is my dad's 64 falcon, was my grandma's. she purchased back in 67'
  14. mustang9093
    mustang9093
    from Indiana
    This photo shop thing is sure a lot easier than welding!!
  15. MUNCIE
    MUNCIE
    from Houston
    Thanks what type of converter did you use?
  16. Ghostcruiser
    Ghostcruiser
    from NE Florida
    If you're talking about torque converter, I used the stock version....:):confused:
    Rob
  17. MUNCIE
    MUNCIE
    from Houston
    yes sir that's what I was refering to.
    Thanks
  18. shortyforty
    shortyforty
    from NH
    That Falcon looks sweet. Is it all Stock?
  19. solo_909
    solo_909
    Hey guys so im going to be picking up a falcon within the next few days and need your help. Im 6'7 and was wondering what I can do to move back the bench seat? Right now I fit ok but would like to move it back 2 or 3 clicks if I could. someone was saying theres a track swap out I could get from a chevy or something that would allow to seat to move back more. Anyone know what to use? another thing is lowering it. I know you can block the back but should I also remove the leaf spring also? whqat about the front I heard I could use a mustang lowering spring? any idea? I know I could cut a few coils but I kinda want to do things the right way. Any words of wisdom would be awesome. thanks = )
  20. MUNCIE
    MUNCIE
    from Houston
    Wish I could tell you but haven't goten to that point yet with my bird.I did talk a guy at the lsr and he cut the front coils and put blocks in the back.I think he took out one leaf but said the ride became really rough.:cool:
  21. A friend of mine is building what will be a pretty damn nice Falcon when its done. [​IMG]
    This is a pic I got of the Falcon someone posted earlier when I saw it running at Coronado. Hopefully it will be there again this year.
  22. darkle
    darkle
    from fresno, CA
    everything is stock except the paint and front seats. The original seats are in the garage. maybe I will have to take it off his hands. :D ;)
  23. pro331
    pro331
    new to board
    Here is a pic of my 64. My plan is to restore it to a 60's style drag car.
      485.5 KB
      522.2 KB
  24. AndrewnTX
    AndrewnTX
    from Plano, TX
    What a thread :D I would be honored if my 63 Sprint could join in!! This car has been my first 60's Ford, and a ton of fun. I got it in pretty much stock configuration and gave it a bit of at***ude w/ AirRide suspension, American Racing wheels and some garage time...
  25. James Maxwell
    James Maxwell
    from So-Cal
    Now that's the way to do a G***er!
  26. James Maxwell
    James Maxwell
    from So-Cal
    One fabulous Ford!
  27. 61falconwagon
    61falconwagon
  28. MUNCIE
    MUNCIE
    from Houston
    Any suggestions on how high can I go with a stall converter on a c4 2800-3500 ?
    Want a application that will not over rev the engine on long distance driving.
    The basics are a 260 bored 30 over stock everything else.Rear end will probably be running 3.73 or 3.50 gears.I think 3.73 will be the highest I could run without it reving too high.Just want something with some bite and still be able to drive it to austin etc.
  29. Falconred
    Falconred
    With a basicaly stock engine you only need a stock converter. If you had a cam change and such you might need more converter. The stall speed of the converter has little to no affect on a daily driver with just a gear such as those you mention, in fact a high stall converter will make for some jerky starts on the street.
  30. MUNCIE
    MUNCIE
    from Houston
    Thanks for the info I'm looking into a larger cam right now.Nothing too extreme just something with a little lope.Was checking TCI website last night they had some good info.
    :cool:
