Features Falcons done right?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Nov 20, 2005.
  1. 55kustomzombie
    55kustomzombie
    My 61 ranchero is really bumpy from the rear end, so i change my rear shocks this weekend but still bounces a lot from the rear. Is this a common problem with these cars or do you guys think my leaf springs are just weak? if so any suggestions? advise?
    I really want to fix this issue before i install lowering blocks.
    Thanks
  2. Ghostcruiser
    Ghostcruiser
    from NE Florida
    Mine does the same thing, even lowered with 2" blocks. I added coil-overs, but it still sways like a drunken preacher at 60+mph highway speeds, or when I take a railroad crossing...;)
    Rob
  3. alecard
    alecard
    Some pics from Argentina... All friends
  4. need louvers ?
    need louvers ?
    I think you guys are going the wrong direction. These cars tend to be a bit stiff on the rear springing in my opinion. When I did my '62 about twenty years ago, I had my springs dearched a bit, and pulled a COUPLE of leaves out. Made a big difference in handling and ride qualities. Also have to be real careful with shocks on these as well. Too stiff is not going to be good. You gotta remember thay these are some seriously lightweight cars.
    Just another quick note, and not to sound like an ***, but there are two reoccurent Falcon threads on the board. This one, which I always figured was to show off finished or driver cars, and "Doing Falcons right" which I always thought was more geared to technical issues with these cars. maybe I'm wrong, but wouldn't it be nice to kinda keep them separate for the sake of reference and both cruising along?
  5. falconizer_62
    falconizer_62
    Yes, I was thinking the same thing...
    put the right wrench in the right drawer.
  6. 55kustomzombie
    55kustomzombie
    Sorry about that guys!!!, moving my *** to the right section.
    ThAnks for all the help though !!!
  7. Ghostcruiser
    Ghostcruiser
    from NE Florida
    How can too many Falcon threads on the HAMB be a bad thing? :):p
    Rob
  8. falconizer_62
    falconizer_62
    It can't! but...
    If there's more than one, then they must serve different purposes...
    BTW, was at Fab Fords this weekend, and hardly any roundbodies were representing! Falcon section overall was understated :-(
  9. A work in progress shot of the '64 Ranchero.
  10. falconizer_62
    falconizer_62
  11. Thats gonna be ***s when it's done!!
  12. jonahboo
    jonahboo
    from NJ
  13. Starting the mini tub...[​IMG]
  14. Moving the inner wheel wells...
  15. Bigcheese327
    Bigcheese327
    That's slick. Much nicer than the typical square-edged tubs you used to see in pro streeters.
    -Dave
  16. Thanks man, I was going for a stealth look. the 235s that were on it originally rubbed on the spring and outer wheel lip, but now there is room for 295/50/15s.
  17. Gasser1961
    Gasser1961
    Got the old Trouble-Makers Green Slime out for the first time last weekend. Needs more work but getting there. Thanks G***er Jeff! Hey why are all the other cars so low to the ground????
  18. Pics Taken at 'Fords at the Summit' in Norwalk, Ohio.
  19. Another 'wheels up' shot from Norwalk.
  20. here a pic of the shirts from speedworld nostalgia race .
  21. not my photo ...lol but there is a falcon in there somewhere.:D..
  22. big b's falcon out of kingman ,arizona ..
    392 hemi ...
  23. good buddy of mine's......stan blosk a/gas !
    700 ci of ford and a liberty 5 speed
    and yes, it still has a straight axle!
  24. bonez
    bonez
    from Slow lane
    bad *** dude! 61 to 63 used to be my fave Falcons, butlately i have a thing for 64 65s.
    The stance and mags on your are rad, but i would ditch the blackwalls, redlines would be perfect for your racer look, and give it some style while at it. gotta have one someday.
  25. Bigcheese327
    Bigcheese327
    Redlines would look good on there. You don't see enough redlines on hot rods.
    -Dave
  26. is there any other drag falcon/ranchero guys in here ?
  27. Bigcheese327
    Bigcheese327
    I'm afraid most of what you're posting is a bit modern for the HAMB; a "done right" drag Falcon is a g***er rather than a pro stocker.
    -Dave
