Features Falcons done right?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Nov 20, 2005.
  1. 1971BB427
    1971BB427
    from Oregon
    If he didn't he should have after the burnout. Looked like the Camaro fell asleep at the light.
  2. 63comet
    63comet
    If you search the name you can find more videos of the car, some in the garage showing of the engine.
    It's not quite HAMB friendly under the hood but he seems to have kept everything as low key as possible. No forced induction or nitrous that I noticed.
    It's running a single downdraft two barrel weber which is odd to me. It's an IDF which I'm used to seeing mounted with one venturi per cylinder. For some reason I was under the impression they couldn't be properly tuned otherwise.
  3. 1971BB427
    1971BB427
    from Oregon
    I think if I were going "low key" the hilborn style scoop wouldn't be part of that equation.
  4. 63comet
    63comet
    Mostly low key? :)
    I guess what I mean is it seems any changes made have been in the "this is safer or faster" category.
    I'm just jealous of his I-6 that'll lift the front wheels, ok?
  5. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Says the man with a straight axle, BBC, and pie crust slicks, Hahahaha!:D
  6. Dave_D
    Dave_D
    from NY
    This guy was flying through the streets at the Watkins Glen vintage fest last weekend. I wish i could have got a better picture...
  7. hotroddon
    hotroddon
    You're welcome, gald they worked out for you!
    This is one of those deals that always turns into a bit of a ****storm, but I'm going to jump in anyway. I am going to start a separate post on this ....
    That car is pretty well known in the vintage road race scene. It is a pretty nice piece!
  8. hotroddon
    hotroddon
    This will probably start some arguments, but I have spent a lot of time looking into this and think I have a pretty good handle on it.
    Guys have been doing Mustang II conversions for quite a number of years now, with varying degrees of success. But there have also been problems ***ociated with it.
    The number one problem is the Falcon/Mustang platform was never designed to carry the suspension loads through the lower stamped unibody frame rails. By design these cars were made to spread the load through the upper shock towers and inner fenders into the cowl. Braces were made that support the top of the shock tower to the center of the cowl. These did two things, they gave the tower support back to the cowl, and they also helped with ch***is twist by triangulating the the towers and cowl.
    When you cut the towers out and eliminate the braces you are now asking the lower frame rail to carry all the loads - something they were never designed to do.
    This is a big enough problem that convertibles have been known to crack the windshield over things as everyday as railroad crossings. It can also be seen in cars that are driven hard in things like the fender gaps changing.
    Now lots of guys are going to chime in and call BS saying that they have 10 million miles with an MII and they have never had a problem. And the truth is, in many cars that are more of a cruiser the problem may never become an issue.
    Now here is where my study and research got kind of interesting ~ and Ironic. I sold one of my cars with an MII conversion to an Engineer at Ford. And he told me an interesting story about a group of guys at Ford that play with early Mustangs and Falcons. They had seen this issue with twisting and movement on a few cars and with some knowledge of engineering and the ability to do drawings, and computers with the power to due finite element type ****ysis, they could simulate what was happening. This confirmed what was believed by some of us as to what was happening. To cure it for those who still wanted to run MII type suspensions, especially on convertibles or cars that were road raced with sticky tires, we looked at a series of tubular braces that started on the frame rail and came up to the firewall with a 90° plate at the intersection of the firewall and inner fender to spread that load. Then a secondary pair of braces were developed to triangulate those bars to the center of the cowl/firewall like the factory braces. Simulated in the computer again, this seems to have strengthened the front clip back to higher than factory levels.
    Now comes the sixty four thousand dollar question, Is this Really necessary? The answer isn't easy, as it depends. Is the car just a cruiser and not going to be abused or raced? Is it fortunate enough to live in an area where major potholes are not a problem? In those cases, on non-convertible cars, then No it is not really necessary. My own Ranchero has done many thousand miles with an MII conversion and no signs of any problems.
    So what if you do want to auto cross one? Or do track days and have some sticky tires. In these case I would say you are going to have issues at some point. And this is another area where some are going to disagree, but I would NOT put an MII in a car destined for this kind of life! Like I say, I have put a lot of research into this, so for my own 63 Convert, I came to the conclusion that I was better off working with the factory design and modifying it to suit. The Mustang II design, while compact, stout and well supported by the aftermarket, is NOT a design that was optimized for handling. It has a fairly short spindle and not a very good camber curve. The original Falcon design has a terrible camber curve, lousy brakes, ****py lower control arm retention, and sloppy steering. But it does have a decent spindle and is also well supported by the aftermarket. Large tube headers can be a *****, and bigger motors are a down right pain in the ***. But modifying the stock towers can alleviate these issues without losing the integrity of strength. The camber curve was figure out by some guy named Carroll Shelby a long time ago, and has since been further refined. The sloppy steering is easy to fix with bolt in Rack & Pinion set up and better control arms are available from a few sources. The only other issue is the tension rods and stronger ones with spherical bearing and caster adjustment are also available.
    Here's where I ended up. Global West tubular upper A-Arms with Del-A-Lum bushings, Global West Springs, Koni Adjustable shocks, Modified stock lower arms (Spherical bearings on the pivot and boxed in lower paltes), Adjustable Tension Rods with a spherical bearings, and a custom Rack & Pinion using Woodward Steering control valve and TCP body. I also got ird of the outer tie rod ends for heim joints with adjustment shims for setting up the Zero Bump Steer. This front end works 100 times better than any MII I had ever done before.
  9. GrantParker
    GrantParker
    from Atlanta
    I have a '63 that is pretty stock.
  10. Thefalconkid
    Thefalconkid
    How about if it has frame connectors, and a cage? My 63 1/2 2 door hard top has 2 X 3" .120" wall frame connectors that p*** through the floor, and a 10 point chrome moly cage. I thought about p***ing through the firewall, but the ch***is guy said that it wasn't necessary to p*** tech.
  11. 1971BB427
    1971BB427
    from Oregon
    Yep! Mine's definitely NOT low key! LOL
  12. need louvers ?
    need louvers ?
    Well, over the years I have been very careful to post pictures of my wagon in the "Doing Falcons Right" thread as it's always been a project. Today, I regret to announce, it's done... Went to lunch with some friends today and came back to find that it was hit by a drunk driver at 1:28 this afternoon. I'm afraid it's wounds are mortal.
    This marks the second time I have had a car hit and destroyed in front of my home in less than six months. Another hit and run. Both events by people at the very exclusive high rise condo tower at the end of my street, The Regency. This one actually made the lower story parking garage, where after a bit of investigation with the grounds staff we found a half a P.T. Cruiser.
  13. Man that just plain ****S............:mad:
    Did you find the driver too?
  14. need louvers ?
    need louvers ?
    The Police are with her right now....
  15. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Damn, Chip. :mad:
    I started to post "death by carbon monoxide" , but I figured that would be counter productive and just plain wrong.
  16. Jeem
    Jeem
    Alliance Vendor
    Dude? WTF? Bummer man....****s!
    Tried to fold that poor car in half?!
  17. need louvers ?
    need louvers ?
    I'm in deep shock right now. I have a friend coming over that is in the Insurance biz to help me maximize the claim on this deal. Fortunately it wasn't my '62 coupe that I have had for the last thirty years, and I do have the Ranchero that started this whole deal again a couple of years ago in the back yard to quickly resurrect.
  18. Camaro Mike
    Camaro Mike
    Need Louvers that's terrible.
    I've enjoyed watching your wagon come together and hoped that someday my Comet wagon project would be as nice. I'm very sorry to see your post.
  19. Alfster
    Alfster
    Sorry to see it banged up like that. [​IMG]
  20. Alfster
    Alfster
    I suppose this is a like it or hate it thing but, the paint on the hood was pretty bad so I thought we would try the stripes. They match in and carry the white from the interior.
    Never seen this done to a round body before....... [​IMG]
  21. Man, you must be gutted! I'd been following your build and watched all the work you and your little lady had put into that wagon . Really feel for ya .
  22. gimpyshotrods
    gimpyshotrods
    Damn, that really ****s. Glad nobody got hurt.
  23. Muttley
    Muttley
    I posted this in another thread last year and I feel like it more than applies to this situation:
    In addition to the insurance fixing the car there really needs to be something along the lines of an "Immediate Satisfaction Law".............you smash my car doing something idiotic (like yammering away on your cell phone while you should be paying attention to the road) and I'm en***led to one free swing (bat, golf club, tire iron or similar weapon(s) allowed depending on the severity of damage) without repercussion.
  24. mikeey rat
    mikeey rat
    from Australia
    Wow sorry for ya ...Happened to my wife once with my young son in our wagon Guy in a stolen car getting chased by the cops.He backed up and rammed her again to push her out of the way then took off again .Wow he hit your wagon so hard he made your moon sticker go google eyed
  25. Bigcheese327
    Bigcheese327
    Wow. That is awful. I'm very sorry, NeedLouvers.
  26. tpw35
    tpw35
    Does anyone know if a leaf spring bushing kit for a 64-65 mustang will work on a 65 falcon, I know they share alot and I can find a kit for a falcon, I can go pick a kit up from Summit for a mustang.
  27. Fingers
    Fingers
    Sad to see a car last 50 years, then get killed by a PT Cruiser..
  28. whtbaron
    whtbaron
    from manitoba
    It is...but he should hang onto the wreck as part of the claim...there's a lot of cherry parts there that could be transplanted onto another project.
  29. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Dude.....this still ****s.
    Anyhow-
    Acorrdin' to my interchange manual thing, both 64-65 Falcon and Mustang leaf springs are 2 1/2" wide have a 2 1/2" diameter front spring eye bushing n' use a 1 3/8" bushing on the end...it don't cover spring shackles though...
    Edited ta' add: Shackle kit part number appears ta' the same:
    <TABLE cl***=fillwidth cellSpacing=0 cellPadding=2><TBODY><TR><TD></TD><TD>C4DZ-5630-B</TD></TR></TBODY></TABLE>
    Front spring eye bushings share the same number, too:
    C4DZ-5630-C
  30. 63comet
    63comet
    I know it'll be a ackward on a mordoor but this is kind of my eventual goal. I wanna go zoom zoom around corners in style!
    I'm interwebbing from a four inch screen, are those side pipes I see?
