fame rails
Discussion in 'The Hokey Ass Message Board' started by Gumboot, Mar 19, 2010.
  1. Gumboot
    Gumboot
    So when building a frame from scratch, what sized materials have you all used? And how much hp/trq are you running on that/those frames?
    I have a '34 Chev pickup that a customer wants built into a custom rat rod. It'll start as a rat rod but as he saves up more money, we'll slowly build into a full on street rod. So, we want the frame to be good and sturdy and able to handle a good 5-600rwhp later, but will only be handling 3-400rwhp at first.
    I know that structural design is an important part and it will be built properly, but what materials have you all used?
    Cheers
    Kevin
  2. Midwest Rodder
    Midwest Rodder
    We have used 2x4 boxed steel for the one we built, it had a close to stock 350 and auto. Zd 12 in the rear, no problems to this day. He drives it quite a bit durring the summer months.
  3. N8B
    N8B
    Kevin,
    Rat Rod frame rails are usually made out of cardboard or particle board can be acceptable.
    Street rods generally require frame rails that will be gold plated so a good thick tin based metal will do fine.
    All jokes aside.
    .125 for mild applications (common early production stampings were .125) or 3/16's for heavy will usually do it.
    Or as noted above you could use rec. tube.
  4. brucer
    brucer
    from western ky
    i like 3/16wall 2x3 rect. tubing
  5. hotrod56cars
    hotrod56cars
    I used 1/8" thick 2" X 4". Stock 289/auto.
  6. carkiller
    carkiller
    I use differnt sizes, 2x3 2x4 and 2x5 but allways 3/16
  7. .120 wall 2" x 4" rectangular tubing is a good place to start. Art Morisson uses it for a lot of his frames. The key to strength is in the frame's ability to resist the twisting forces imposed by torque and suspension dynamics. This means you need to design your center cross member to do more than support the transmission. A cross member forward of the rear suspension with a drive shaft hoop provides a lot of strength and a good place to anchor rear suspension arms or "bars."
  8. Fenders
    Fenders
    I used the same tubing for the rails on the car in my avatar.
    302 engine, auto.
  9. Rickybop
    Rickybop
    A "K" member or "X" member will strengthen the frame substantially.
  10. Gumboot
    Gumboot
    Awesome, good info, keep it commin.
    I guess the next question will be: Got pics of your frame designs? and finished frames?
    We found an unknow year Fargo box to use on the project yesterday. That's goin to ook pretty rad when I'm done.
    Cheers
    Kevin
  11. scrap metal 48
    scrap metal 48
    Here's one I did for my truck...117" wheel base. 6 1/2" front Z and 14" rear Z. Used 2x4x.120 wall............
  12. s**** metal, you goin to the M&G?
  13. Gumboot
    Gumboot
    Good info, got any pics of what you mean?
