Technical Fan blade with a severe duty fan clutch?
Discussion in 'The Hokey Ass Message Board' started by midnightrider78, Jan 28, 2015.
  1. midnightrider78
    midnightrider78
    I just got a 17" Flex-a-lite fan blade and a Hayden severe duty fan clutch to use on my '56 Chevy. This car has a 383, Super T10, 4.11 posi, and a downflow radiator with shroud. I had originally intended to go with a standard duty fan clutch but after doing some reading decided that the severe duty fan clutch may serve me better. Upon receiving these parts, I see that the fan blade has a sticker which says to use only with a standard fan clutch. I believe this has to do with the pitch of the blades.
    So now I'm wondering: Can I use these pieces together anyway or do I need a different fan blade?
  2. Is it a fan like this? If so you want have a problem but one of their thin blade fans I wouldn't try it.HRP
  3. stimpy
    stimpy
    with the severe duty turning faster it might pull the blades into the radiator from flexing at the base or cause it to fail at the rivets from pull out because of the rotational speed ( Fords had a problem with this back in the seventies and it wasn't cool to drive hear a bang and see a blade sticking thru your hood besides destroying other stuff under it . ) ..
  4. harpo1313
    harpo1313
    from wareham,ma
    I always thought that a solid blade fan ,as Hrp shows is required for a clutch setup.
  5. midnightrider78
    midnightrider78
  6. Does your clutch have a 8 bolt attachment like the fan? HRP
  7. jseery
    jseery
    from Wichita KS
    Why would you be using a clutch with a flex fan?! The clutch is for a ridged fan blade. The flex fan is for use without a clutch, as the name implies, if flexes with fan speed.
  8. Every clutch fan I've had used had a solid-blade fan.
  9. stimpy
    stimpy
    thats a high pitch fan , needs slower speeds the tips will pull into the radiator .
  10. stimpy
    stimpy
    it cools better at idle speeds and doesn't overcool at high speed and the clutch will allow the fan to speed up and slow down with temp if it needs too and doesn't make the noise like a fixed fan does .
  11. The photo of the fan I posted is also a flex-a-lite fan but only in name,it is a steel bladed fan and incidentally I have this very fan on all 3 of my hot rods. HRP
  12. jseery
    jseery
    from Wichita KS
    I understand how a clutch fan works and I understand how a flex fan works, just no idea why you would want to couple the two.
  13. jseery
    jseery
    from Wichita KS
    Ok, my mistake, I thought we were talking "flex" fans, we are just talking a brand name. Yep, a clutch is a good idea with a solid style fan.
  14. Boryca
    Boryca
    from Detroit
    Flex-a-Lite is the manufacturer, my friend. It's a rigid fan.
  15. I wouldn't use one of these things if you paid me,,they are junk & dangerous. HRP
  16. stimpy
    stimpy
    and noisy as heck too ..
  17. Roothawg
    Roothawg
  18. midnightrider78
    midnightrider78
    Forgot to mention also that the radiator is in the 6cyl position.
  19. flux capacitor
    flux capacitor
    Their sound reminds me of waitin for the school bus as a kid, they sound like a mid 70's gmc 366 log truck, sold all my old ones at a swap meet last year. Non thermal fan clutch's are ok in my book for heat probs n more air at low rpm's.
