Technical Fan on 8BA Loose on Shaft
Discussion in 'Traditional Hot Rods' started by "Big" ED, Jun 11, 2023.
  1. "Big" ED
    "Big" ED
    from Texas
    I'm a Nailhead Guy and new to the Flathead scene. The fan on my 8BA is loose and causing one heck of a vibration. From what I understand, these have a crafty little clutch setup and the way it wobbles, it feels like the clutch has ****ped out.
    I've been busy and haven't had time to dig into it yet, but before I do; I'd like to know what I'm getting into.
    It appears the shaft and the ***embly are one and I suspect there are bearings inside that are no longer there, am I correct?
    1. Does the shaft come off after the two nuts are removed?
    2. Once off, does anyone have a link or information on how to dis***embly/rebuild one of these?
    3. Anyone know where I can get a rebuild kit or replacement?
    Thanks, and appreciated.
    Keep them out of the 'yard!
    Brother ED.>
  2. Mac VP
    Mac VP
    '28phonebooth, vtx1800 and CSPIDY like this.
  3. bubba55
    bubba55
    Ding Ding
    This is why I Luv da HAMB
    We are all in this together
    Rock on HAMB
  4. Mac VP
    Mac VP
    Just a short additional comment here….there’s no clutch inside the hub, nor are there any conventional bearings (ball or roller or needle type). The very hardened shaft runs on a film of oil inside the casting called a spindle bearing. The maintenance and proper refilling of the oil cavity is very important. If maintained correctly, it will last a long time.
