Technical Fan shroud question
Discussion in 'The Hokey Ass Message Board' started by I_be_moose, Mar 3, 2021.
  1. I_be_moose
    I_be_moose
    Need to lay out for a fan shroud on my Model A coupe project. The fan is not square to the radiator. I want to have the opening in the shroud square to the fan correct? Just making sure My thinking is in the right direction.
    moose
  2. The info I found was that you want the fan about half way inside the shroud for best results. Reasonably even gap around the cir***ference between the fan and shroud also.
    Just Gary and oldiron 440 like this.
  3. squirrel
    Yes, the fan opening wants to fit nicely around the fan. The radiator end of the shroud wants to fit nicely against the radiator.
    pitman and Just Gary like this.
  4. Bandit Billy
    Bandit Billy
    To visualize, this is a C3 Corvette fan shroud. It is the most dramatic example as the radiator is drastically slated under the low nose of the car. The shroud is thin at the top and fat at the bottom so the fan sits squarely in the opening.
    Just Gary likes this.
  5. rockable
    rockable
    Also, don't make it too shallow or you will not get good flow across the entire core.
    SakowskiMotors likes this.
  6. jimmy six
    jimmy six
    This one on a 40 Chevrolet. The aluminum kit was bought from Speedway in the Circle Track section/catalog. We measured the radiator body, and followed the instructions. It was made for horizontal use but we turned it vertical. Painted it satin black. D5978EC3-E831-4426-952A-2993EF3712DF.jpeg
    Packrat, Just Gary and Desoto291Hemi like this.
  7. 31 B'ville
    31 B'ville
    from SE Pa
    Fabricated mine from s**** steel shelves. The fan was far from being square with the radiator. 474E4374-CA75-44F4-AC83-0CEB8E6CC4B5.jpeg 075D390F-E3E9-4362-B977-DA5866700210.jpeg
    pitman, Bandit Billy, Packrat and 2 others like this.
  8. stuart in mn
    stuart in mn
    Ron Covell recently posted a video on how to form a metal shape that's round on one side and square on the other (like a radiator fan shroud) that was educational:
  9. SPEC
    SPEC
    The fan should be 1/3 in the shroud and 2/3 out for the maximum air movement.
  10. SakowskiMotors
    SakowskiMotors
    Can you explain in more detail?
  11. Just Gary
    Just Gary
    Made my '28 sedan's shroud out of 1/2" thick MDF, an old T-shirt & fibergl***.
    My fan is square to the radiator, but I think what's most important is (1) the shroud is tight against the radiator and (2) the gap is between the shroud & fan isn't too big (I trimmed my shroud so it has a consistent 1/2" clearance).
    20201003_054850~2.jpg 20201004_191511_2.jpg 20201006_100526_2.jpg 20201012_102629_2.jpg 20201028_165241_2.jpg 20201028_165454_2.jpg 20201029_085027_2.jpg
    lothiandon1940 likes this.
  12. Bandit Billy
    Bandit Billy
    In my 41 PU I went the same route as @jimmy six above with a somewhat generic aluminum shroud from Summit that measured the same as my core. I had to cut the fan hole and the fan surround, I added some brackets to the radiator to make the shroud a bolt on, then I did some riveting and powder coating.
