Technical Fan Shroud question
Discussion in 'The Hokey Ass Message Board' started by vintage44, Dec 27, 2023.
  1. vintage44
    vintage44
    from NY
    I miscalculated the distance in front of my 350 and mounted an electric fan on the back of an aluminum rad because I thought the engine mounted fan was too far from the rad to be efficient. Duh! Now I have the electric fan in place AND there is enough clearance that the engine mounted one ALSO fits! I have both in place now and my question is - should this setup work OK without any kind of shroud?
  2. I do not know for sure. :confused: Maybe mount another fan in front of the radiator. :rolleyes::)
    The people with experience with this will be here soon.
    Happydaze and twenty8 like this.
  3. pprather
    pprather
    I'd think about removing the electric fan. Put a fan spacer on mechanical fan to get it near the radiator.
    If it doesn't overheat in the summer while idling at traffic lights, then no shroud would be needed.
  4. miker98038
    miker98038
    The electric fan is just blocking the mechanical fan, I’d remove it. Get the mechanical fan the right distance from the radiator and go. A shroud always improves the cooling if done properly. What kind of car/installation?
  5. twenty8
    twenty8
    With a good shroud, you can have the mechanical fan back a little from the radiator with minimal negative effect.
    guthriesmith likes this.
  6. swade41
    swade41
    from Buffalo,NY
    I think the electric fan will block the air flow the mechanical fan is trying to pull through
  7. Oh boy, a buddy of mine back in the Bay has a '50 Plymouth with a SBC in it that likes to run warm. At one point it had a mechanical fan and an electric one inside the shroud. Still ran hot. If you don't have this problem then I would choose one or the other.
    I was never able to help him get it sorted out, with all of the timing adjustments, A/F adjustments and t******* the fender wells back to get the heat out, it fought everything we threw at it. Once the hood was ventilated it became bearable, but never right. It was a frustrating experience that spanned months.
  8. hepme
    hepme
    Hard to beat a good clutch fan with a proper shroud fitted right.
    Deuces, lostone and pprather like this.
  9. larry k
    larry k
    “ No “ !!!!
    ProtoTypeDesignFlauz likes this.
  10. twenty8
    twenty8
    As he has them, the air flow will be limited by the fan that is least efficient. The weaker fan will become an obstruction to the stronger one. The only way it would work is if the two fans worked "side-by-side" instead of in line.
    Think "in parallel" instead of "in series".
  11. ekimneirbo
    ekimneirbo
    Remove the electric fan and use the engine driven fan. Then make a shroud for mechanical fan.
  12. Jkmar73
    Jkmar73
    from Tulare, CA
    I would remove the electric fan and just run the mechanical one. But I would definitely use a shroud. That will allow the fan to pull heat from the radiator more efficiently. As the air flows through the radiator, the shroud will act like a funnel for the fan to pull the hot air out.
    firstinsteele, Deuces and lostone like this.
  13. i7083
    i7083
    As stated, mechanical fan with a spacer. Build your shroud deep enough to cover 1/2 to 2/3 of the fan blade.
    lostone likes this.
  14. Deuces
    Deuces
    Huh????.....o_O
  15. G-son
    G-son
    from Sweden
    You could have the fan in the back seat, as long as you have a proper shroud/ducting making sure that as much as possible of the air moved by the fan is ****ed through the radiator.
    It's when someone puts the fan some distance away from the radiator without anything forcing the air to move through the radiator it all fails. Mother nature is just like me quite lazy: if it's easier to **** air in from the sides between the fan and radiator than pulling it through the radiator, that's what will happen.
    firstinsteele and twenty8 like this.
