Fan shroud vents
Discussion in 'The Hokey Ass Message Board' started by rusty48, Apr 21, 2007.
  1. rusty48
    rusty48
    I bought an electric fan and shroud at Auto-Fair .It has little rubber flap vents in the corners. Shoudn't they be turned so they open to the inside with the shroud in front of the radiator?
  2. hotrodbrad
    hotrodbrad
    from Tempe, AZ
    not sure why you would run a shroud in front of your radiator :confused:
  3. atomickustom
    atomickustom
    hotrodbrad's right - a shroud in front of your radiator will impede airflow over the radiator at highway speed unless you're running a big and powerful fan. Shrouds are usually for puller fans mounted behind the radiator.
  4. seldom scene
    seldom scene
    The shroud goes behind the radiator, the flaps help air flow at highway speeds.
