1952-59 Ford Fan shroud
Discussion in 'Off Topic Hot Rods & Customs' started by Ian hall, Oct 2, 2014.
  1. Ian hall
    Ian hall
    from Uk
    Fitted a shroud to my 289 falcon and it helped a bit with cooling. My 53 runs fairly warm wondered whether it's worth making one for that too?
    Thanks
    Ian
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. Ian hall
    Ian hall
    from Uk
    Worth fitting tho?
    Ian
  4. bobss396
    bobss396
    Oh snap... that is cool. I'm considering a Mustang radiator for my car and that shroud might be good. Beats cutting one out of tin stock and riveting it all together.
  5. Ian hall
    Ian hall
    from Uk
    I was going for the tin option!
    Ian
  6. fordsbyjay
    fordsbyjay
    from Lafayette
    A shroud always helps air flow. With no shroud the fan just blow air around the engine compartment at low speed and doesn't really **** air through the radiator.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Engine driven fan or electric? HRP
  8. bobss396
    bobss396
    I used to make them for my stock cars out of relatively light aluminum. In case of a crash I wouldn't lose the fan or have it push into the radiator.
