1952-59 Ford Fan Shrouds and Brackets
Discussion in 'Off Topic Hot Rods & Customs' started by 53vicky, Jul 26, 2022.
  1. 53vicky
    53vicky
    Hey everyone,
    So I just installed a new radiator in my '53, and would like to put a shroud on it. On my previous radiator, I used one of the Sprectre 3" shroud that includes the nylon mounting kit that goes through the radiator. However, I'd like to get away from that if I can and use a bracket mounted shroud instead of putting holes in my radiator. I'm still running a 6 blade mechanical steel fan.What are you guys using for shrouds and brackets?
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. jimmy six
    jimmy six
    I’ve used the ones from Summit on 2 different vehicles. Always the solid ones and cut the hole myself. I bought them to fit the radiator core as the have a lot of sizes. Took some work to fit correct but worth it.
    JeffB2 and 53vicky like this.
