1952-59 Ford FAQ Sticky
Discussion in 'Off Topic Hot Rods & Customs' started by EchoOfGecko, Feb 25, 2011.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. sobpunx
    sobpunx
    Does any one have a definite answer to what heater core will work in a 54? I read that a 78/79 f-100 will work and a early comet/falcon will work. (the heater core in my 54 was out of something different as they jb welded the tabs on) Some guys have adapted mid 80's Ford Ranger cores. From "Sticky" Page 5 Post# 137 Autozone part Spectra 399025 Around $30.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    Kustomline54 likes this.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
  8. JeffB2
    JeffB2
    from Phoenix,AZ
  9. raceron1120
    raceron1120
    Got some babies that fit - FINALLY! After getting 2 sets of cheap, non-fitting baby moons (or smoothies, as some call them), the set I got from Hubcap Mike's actually fit, very nicely too. They snapped on using the palm of my hand and with no distortion.
    Link to Hubcap Mike's: http://hubcapmike.com/
    A couple of pics :
    Just what I was looking for.
    ffr1222k likes this.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
  11. JeffB2
    JeffB2
    from Phoenix,AZ
  12. JeffB2
    JeffB2
    from Phoenix,AZ
  13. JeffB2
    JeffB2
    from Phoenix,AZ
    Thinking of swapping out a transmission? New coverage on adapter kits now available here: http://www.transmissionadapters.com/ 223 & Flathead to AOD also late model Mustang stick shift to early engines,call for info.
  14. reallyrotten
    reallyrotten
  15. BruceMc
    BruceMc
    from Alaska
    in searching for rear shocks for my '55, these are the 3 choices that came up most often as (affordable) OE replacement. Most sites don't seem to include all options if you choose 'Fairlane' as a model, but Hollanders lists this for the interchange:
    '52 - '56 p***enger
    '57 - '58 p***. w/ metal spring except S.W., convertible, and sedan delivery
    '55 - '57 T-bird
    KYB Gas-A-Just KG5517
    Extended Length: 17.87"
    Compressed Length: 10.91"
    Travel: 6.96"
    Gabriel Guardian Shock 81270
    Extended Length: 17.67 in.
    Compressed Length: 10.56 in.
    Travel: 7.11 in
    Monroe Monro-Matic 31125
    Extended Length 20.75"
    Compressed Length 12.25"
    Travel: 8.50"
  16. JeffB2
    JeffB2
    from Phoenix,AZ
  17. JeffB2
    JeffB2
    from Phoenix,AZ
    Black Wagoon likes this.
  18. JeffB2
    JeffB2
    from Phoenix,AZ
    Update from Watsons on relays,this is valuable info if you are going to rewire your Ford https://watsons-streetworks.com/a-current-topic/ Many of us have added additional accessories and the original ignition switches are not up to handling the load before they fail also a common complaint is dim headlights even after a Halogen upgrade you will not believe the difference after adding the relays.The section "Current topics" covers relays.
  19. JeffB2
    JeffB2
    from Phoenix,AZ
    How to measure for a driveshaft: https://www.dennysdriveshaft.com/how_to_measure.html Ford yokes:http://www.drive-lines.com/dana/******_applications.php?model=Ford 1949-56 Ford front joints are 1" diameter cups with inside snap rings,most C4 & AOD with the 3 1/2" yokes have 1 1/16" cups with outside snap rings If you are using the stock rear end you will need a conversion U-joint with these sizes to attach the front yokes listed,notice the length of the yokes available you may be able to use your existing driveshaft by choosing the correct yoke and U-joint.
  20. JeffB2
    JeffB2
    from Phoenix,AZ
  21. JeffB2
    JeffB2
    from Phoenix,AZ
    Swapping a 3 speed column for an Automatic column when using an AOD or C4.Here's how with pictures:http://1954ford.com/forum/viewtopic.php?f=32&t=2951 Update 12/3/20 Refer to sticky Page 6 for pictures and Tech on the Lokar linkage rod kit which was not available when this was written. The C4 linkage kit is part # ACA-1801
  22. JeffB2
    JeffB2
    from Phoenix,AZ
  23. JeffB2
    JeffB2
    from Phoenix,AZ
  24. JeffB2
    JeffB2
    from Phoenix,AZ
    Here you will find a chart regarding wire sizes pertaining to gauge and to the length of said wire.Many times we will install one wire alternators to eliminate under the hood wiring clutter there is a lot of BAD info out there stating to use a 10 gauge wire to the positive battery terminal from the alternator.Most parts houses will have the cables with to flat eye terminals like Ford uses off the starter solenoid these are usually available in 4 or 6 gauge for around $5-$6 use those for the most common 100 amp one wires.http://www.motorcityreman.com/technical-info.html
  25. JeffB2
    JeffB2
    from Phoenix,AZ
  26. JeffB2
    JeffB2
    from Phoenix,AZ
  27. JeffB2
    JeffB2
    from Phoenix,AZ
  28. JeffB2
    JeffB2
    from Phoenix,AZ
  29. JeffB2
    JeffB2
    from Phoenix,AZ
  30. JeffB2
    JeffB2
    from Phoenix,AZ
