1952-59 Ford FAQ Sticky
Discussion in 'Off Topic Hot Rods & Customs' started by EchoOfGecko, Feb 25, 2011.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Here is a 302 tear down for the SBF crowd:
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    one piece at a time likes this.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. Texas57
    Texas57
    Tip to make this thread come up quickly...somebody may have already suggested, to be truthful, I haven't read the entire thread yet. Anyways, after you open this thread just add it to your favorites. It's the star ****on underneath the red x at the top of this page. click the star, then click add to favorites.
    Edit...this was posted BEFORE the thread was make a sticky....not so hard to find now.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    8.8 rear end Tech,These rears are popular swap material that can be found in later Rangers and Explorers usually under $200 at most Pic-A Parts many have locker rear ends this shows you what to look for and how to read the codes: http://www.therangerstation.com/tech_library/Ford-8_8-axle.shtml A practice becoming popular with these is to use the 31 spline axles that come with disc brakes which are wider than the earlier models,to narrow them folks cut down one side and use the shorter axle on the cut side this gives a rear about 56" wide (makes for EZ tire changing) Here is a video showing the narrowing process on a 7.5" Ranger the same applies to the 8.8" rears. http://www.youtube.com/watch?v=__fsB4ucfkU
  8. JeffB2
    JeffB2
    from Phoenix,AZ
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    Kustomline54 likes this.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
  11. dwaynerz
    dwaynerz
    Can't believe nobody watched or commented on the eastwood paintshaker. The post was made in december, I know, but it would make an interesting garage addition. I know I wouldn't get much done.
  12. JeffB2
    JeffB2
    from Phoenix,AZ
  13. JeffB2
    JeffB2
    from Phoenix,AZ
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    qicvick likes this.
  15. JeffB2
    JeffB2
    from Phoenix,AZ
  16. JeffB2
    JeffB2
    from Phoenix,AZ
  17. JeffB2
    JeffB2
    from Phoenix,AZ
  18. Zapato
    Zapato
  19. JeffB2
    JeffB2
    from Phoenix,AZ
  20. JeffB2
    JeffB2
    from Phoenix,AZ
  21. JeffB2
    JeffB2
    from Phoenix,AZ
    One more of the '53 to 302 swap p***enger side HEDMAN 88400's Butch\'s \'53 swap 4.jpg
  22. JeffB2
    JeffB2
    from Phoenix,AZ
    Just installed the HEDMAN 88400's in my '54 with a 302 here's two shots showing the excellent clearance drivers side and p***enger side. Check out Pg 5 for a 351 with these headers. header2 001 (Large).jpg
    chopd top likes this.
  23. JeffB2
    JeffB2
    from Phoenix,AZ
  24. ajracing9
    ajracing9
    Hey guys...a body of mine just introduced me to this site: www.oldfuelinjection.packrad.net it's an awesome source for ford efi info! Sorry I don't think it hyperlinked but copy and paste.
  25. JeffB2
    JeffB2
    from Phoenix,AZ
    Rui likes this.
  26. JeffB2
    JeffB2
    from Phoenix,AZ
  27. JeffB2
    JeffB2
    from Phoenix,AZ
  28. JeffB2
    JeffB2
    from Phoenix,AZ
  29. JeffB2
    JeffB2
    from Phoenix,AZ
  30. voodookustoms
    voodookustoms
    I just picked up one of these speedo cables and it worked beautifully. Plenty of extra length if you need it, but it is trim to fit so you can have a perfect fit. http://www.summitracing.com/parts/lok-sp1502u This one has the correct ends for 50's Ford to a C4 or AOD I used this in my '54 with a 302& AOD for better routing. https://www.ebay.com/itm/Speedometer-Cable-FORD-MERCURY-AMC-82-has-5-8-threaded-nut-at-speedometer-end/232712085870?fits=Year:1967|Model:Mustang&hash=item362eb8a16e:g:CJoAAOSwC2Jaudwh
