1952-59 Ford FAQ Sticky
Discussion in 'Off Topic Hot Rods & Customs' started by EchoOfGecko, Feb 25, 2011.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. JeffB2
    JeffB2
    from Phoenix,AZ
  4. JeffB2
    JeffB2
    from Phoenix,AZ
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. JeffB2
    JeffB2
    from Phoenix,AZ
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    Kustomline54 likes this.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    This whole page is chock full of helpful body work videos! :D
    54HotRod likes this.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    brushwolf likes this.
  11. JeffB2
    JeffB2
    from Phoenix,AZ
  12. JeffB2
    JeffB2
    from Phoenix,AZ
  13. JeffB2
    JeffB2
    from Phoenix,AZ
  14. JeffB2
    JeffB2
    from Phoenix,AZ
  15. JeffB2
    JeffB2
    from Phoenix,AZ
  16. JeffB2
    JeffB2
    from Phoenix,AZ
  17. cka7
    cka7
    [/QUOTE]
    Champion Radiator now has a "3 row x 1" tube" radiator for our cars at a great price in any configuration you need. Standard set up is p***enger side upper hose and drivers side lower, but for $80 they moved my lower to the p***enger side. They can also set it up for front or rear positions i.e V6 or V8. 07/29/20 Notation Update" The radiator for 1952-56 Ford swaps which is a 1967 Mustang 20" core unit can be had both ways. If you used the early 1965-69 289 "short" water pump you want the radiator listed for a V8 car (p***enger side lower hose outlet) If your SBF has a 1970 and later "long" pump then use the 6 cylinder radiator which has the drivers side lower hose. When you shop ebay put "1967 Mustang Radiator 20" in Search then on the left of the column you will see "brand choice" select Champion.
  18. JeffB2
    JeffB2
    from Phoenix,AZ
  19. JeffB2
    JeffB2
    from Phoenix,AZ
  20. JeffB2
    JeffB2
    from Phoenix,AZ
  21. JeffB2
    JeffB2
    from Phoenix,AZ
  22. JeffB2
    JeffB2
    from Phoenix,AZ
  23. JeffB2
    JeffB2
    from Phoenix,AZ
  24. JeffB2
    JeffB2
    from Phoenix,AZ
  25. JeffB2
    JeffB2
    from Phoenix,AZ
    1firewall.JPG We have found that the 1952-56 cars have issues with radiator clearance if the car had a V8 previously the 6 cyl cars had their radiators mounted more forward and there was a difference in the splash pan attachment panels the pictures below show the fix. 1firewall.JPG Scroll down for additional pictures.
  26. JeffB2
    JeffB2
    from Phoenix,AZ
    From Page 4 Hedman 88400 fit with a 351W & C4 in a 1954 Ford there was a little bit of tweaking with the motor mounts to move it back a little further,check out the pictures to follow. 1firewall.JPG
  27. JeffB2
    JeffB2
    from Phoenix,AZ
    Two more views,the previous owner had put in a SBC :( and had wacked off the original cross member mount pads so they were replaced with new ones. 1firewall.JPG
  28. JeffB2
    JeffB2
    from Phoenix,AZ
  29. JeffB2
    JeffB2
    from Phoenix,AZ
  30. JeffB2
    JeffB2
    from Phoenix,AZ
    In regards to the pictures above,you can see how close the electric fan with shroud are to the water pump pulley. So keep in mind two things and that is first the pan shield requires being cut like the above pictures if you are replacing a Flathead or Y-block V8 the Six cylinder cars already have the radiator positioned further forward. Second notice the last picture shows that the water pump has a drivers side lower hose that indicates it is a 1970 and later "long pump" using a 1966-69 289 short pump and balancer will gain about 4" extra clearance. The picture here shows a 1954 Ford that had a Six and now has a 302 with the early short pump and the radiator in the stock 6 cyl location. engine 54 ford 001 (Small).jpg Also when doing a swap we have found the AOD a better fit than using a C4 regarding the transmission cross member mount the specs here tell the tale http://non-stoptransmission.com/en/info-ford.php This illustration shows why you have more radiator to fan space if you are doing a 302/351 swap in a 52-56 car that had a Six from the factory ,look in the bottom right corner at the sheet metal that moves the radiator mounting forward.
    Rui likes this.
