1952-59 Ford FAQ Sticky
Discussion in 'Off Topic Hot Rods & Customs' started by EchoOfGecko, Feb 25, 2011.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    bondojunkie likes this.
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Top wire on right side is for 12 volts from the BAT on the ignition switch,the terminal under that is taillights. Moving to the left side the terminal at the top goes to the brake switch, middle terminal is parking lights,bottom terminal goes to the dimmer switch. The terminal next to the white block is the rheostat terminal for the dash lights.
    slugo10 likes this.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    More from Rebel Wire: The 50's switch only has one battery terminal and the 9+3 kit only has one battery wire for the headlight switch. So the yellow headlight power wire goes to the "B" terminal of the switch,the larger circuits kits have the two wires (GM and late Fords) should you require a second wire just add a jumper wire off the BAT terminal.Shown in the picture here: https://www.jalopyjournal.com/forum...ne-daily-driver.1027219/page-18#post-12641103 Post # 525
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. JeffB2
    JeffB2
    from Phoenix,AZ
  7. JeffB2
    JeffB2
    from Phoenix,AZ
  8. the-stig
    the-stig
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    Kustomline54 likes this.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
  11. JeffB2
    JeffB2
    from Phoenix,AZ
  12. JeffB2
    JeffB2
    from Phoenix,AZ
    AOD shifting issues ? Rear end ratio may be at fault here is the fix:
  13. JeffB2
    JeffB2
    from Phoenix,AZ
  14. JeffB2
    JeffB2
    from Phoenix,AZ
  15. JeffB2
    JeffB2
    from Phoenix,AZ
    What allows the radiator to be placed further forward in a '54 with a 6 cylinder are the two panels shown in the right lower section here part #6775 & 6776 54 fender.png
  16. JeffB2
    JeffB2
    from Phoenix,AZ
  17. JeffB2
    JeffB2
    from Phoenix,AZ
  18. JeffB2
    JeffB2
    from Phoenix,AZ
  19. JeffB2
    JeffB2
    from Phoenix,AZ
  20. JeffB2
    JeffB2
    from Phoenix,AZ
    Picture of a 1966 Mustang radiator used in a 1952-55 swap with the shorter 1965-69 289 water pump and dampener. (lower hose is p***enger side) 50's.jpg
    Kustomline54 and 54 ford coupe like this.
  21. JeffB2
    JeffB2
    from Phoenix,AZ
  22. JeffB2
    JeffB2
    from Phoenix,AZ
  23. JeffB2
    JeffB2
    from Phoenix,AZ
    If you have done or will be doing An SBF swap you might find this handy to cut down on wiring clutter pretty much plug & play.
  24. JeffB2
    JeffB2
    from Phoenix,AZ
  25. JeffB2
    JeffB2
    from Phoenix,AZ
  26. JeffB2
    JeffB2
    from Phoenix,AZ
  27. JeffB2
    JeffB2
    from Phoenix,AZ
  28. JeffB2
    JeffB2
    from Phoenix,AZ
  29. JeffB2
    JeffB2
    from Phoenix,AZ
  30. JeffB2
    JeffB2
    from Phoenix,AZ
    DrDragon likes this.
