Fargo COE!!!
Discussion in 'Off Topic Hot Rods & Customs' started by 57 Fargo, May 11, 2025.
  1. 57 Fargo
    57 Fargo
    Well this happened…. IMG_5944.jpeg IMG_5947.jpeg IMG_5945.jpeg IMG_5946.jpeg Bought it from a fellow HAMBer. Super great guy. I’ve always wanted a COE.
    How could I resist a Fargo? I believe it’s a ‘59.
    Did I mention it has a Hemi in it?
  2. 57 Fargo
    57 Fargo
    I made the journey on Friday 5 hours each way to pick it up.
  3. Talk about a couple of tons of potential- that is a first for me.
  4. 57 Fargo
    57 Fargo
    I couldn’t say no since it’s the same front as my 57 1/2 ton . Plans are for more modern drive axle and about three feet lower!
  5. squirrel
    that's one you don't see every day
    neat
  6. gene-koning
    gene-koning
    I saw a 57 Dodge CEO in a junk yard in WI many years ago. It was really rusty, and only the cab forward (on the frame, no drive train) was present. I wanted it so bad, but at that time, it was way past my abilities.
    Amazingly, that old junk yard is still going (lots of changes over the years), every once and a while, I wonder if that old CEO is still there. I'd be pretty surprised if it was, its probably been over 20 years since I've been there.
    It sure looked pretty cool to me.
    57 Fargo, Sharpone and porkshop like this.
  7. 57 Fargo
    57 Fargo
    I’ve learned they used the 57 front end until 59 on the COEs, this one has the 58 dash in it
  8. SS327
    SS327
    I like Dodges better. :oops:
  9. Speccie
    Speccie
    That truck looks great.
  10. rockable
    rockable
  11. gene-koning
    gene-koning
    Considering how few actual CEO trucks Dodge probably sold during that time frame, them not changing the front sheet metal isn't all that surprising. The 57 nose fit the era well, and the 60 was a completely new truck, with different sheet metal.
  12. RodStRace
    RodStRace
  13. Don't take forever! I'm getting OLD.
    Ben
  14. 57 Fargo
    57 Fargo
    Bought a twelve valve ***mins for it today.
  15. RodStRace
    RodStRace
    If I remember correctly those are the dangerous rims, but I always dug the mag wheel image they have.
    If there is a way to keep them, it would be great to see.
    osage orange, Sharpone and porkshop like this.
  16. 57 Fargo
    57 Fargo
  17. gene-koning
    gene-koning
    Are ya done yet (is it too early...)? :D
  18. 57 Fargo
    57 Fargo
    Ha ha ha! I haven't even got it off the trailer yet
  19. snoc653
    snoc653
    from Iowa
    In my opinion dropping the body will detract from the COE cool factor. You could put the cab on a Super Duty frame if you wanted it low. I would consider going a different route depending on your final goal. I would use a drum box or sleeper behind the cab and channel it so it ties into the original cab height. The sides of the channeled sleeper would hide the fuel tank and allow storage space under the floor giving it that lowered look. If you wanted to pull with it, you could extend the frame and put duals on it with either a true truck hitch or a goose neck hitch on it to tow s trailer. Or keep the single rear and turn it into something like a toter home.
  20. 57 Fargo
    57 Fargo
    I would wait until you see what i'm doing before telling me how I should build it. I am keeping the frame, currently looking for a dana 80 or 110, it will get lowered to a reasonable height with a deck and a fifth wheel to pull my trailers, no where did i say anything about lowering the cab or extending the frame, a sleeper is awfully hard to do with the big back window.
  21. snoc653
    snoc653
    from Iowa
    Wasn't trying to tell you how to build it. I expressed my opinion. It's yours build it how you want. What I think has sorta been done before but not exactly how I would do it.. Your engine choice in my opinion is spot on. I would throw super singles on the back to give it a more modern appeal. Again, what I would do, not what you have to do. I could even see the sleeper concept allowing you to use a more traditional bed like your pickup has. I like seeing projects and thinking about what I would do. Then sit back and see what they do. The only thing I would ask you to do is keep on impressing us with your workmanship.
    osage orange, 49ratfink and 57 Fargo like this.
  22. 57 Fargo
    57 Fargo
    I’m on the hunt for an Eaton Fuller 7-10 speed overdrive for this thing. Should be fun
  23. 65pacecar
    65pacecar
    from KY, AZ
    Nice. The 12 valve is a reliable pulling beast. That will be a great combo. Many years ago a guy had a 48 work dodge truck running a 24 Valve ***mins at the show, flat bed with a 69 Hemi Charger on the bed. The Charger barely received a glance, but the well built truck had a crowd all day long.
    Enjoy the build.
  24. 57 Fargo
    57 Fargo
    I’ve had a few 12 valve pickups, this one is a ‘96 so the easy to turn up p pump. My goal is to use this truck to pull my trailers, it’ll have a fifth wheel on it
  25. leon bee
    leon bee
    3 feet lower? Just down off the trailer be about right.
  26. 57 Fargo
    57 Fargo
    3 feet was sarcasm... It defiantly needs to be lower though
  27. leon bee
    leon bee
    Beautiful truck, glad it's being saved.
  28. 57 Fargo
    57 Fargo
    I'm excited, I'm not sure how much I will get done this year. I have to make some progress on the T-Bird project for my wife. I am mostly focused on collecting parts for the COE at this point.
  29. SS327
    SS327
    No interior pictures? No engine pictures? What engine is in it? Will it crank? Can you get it running? You should know by now we need more. :mad::D
  30. 57 Fargo
    57 Fargo
    Patience my good man, it’s still on the trailer, Tomorrow I’ll unload it and play with it some!
