fastener grade question
Discussion in 'The Hokey Ass Message Board' started by model-a-fan, Mar 4, 2009.
  1. model-a-fan
    model-a-fan
    from Kentucky
    Are grade 5 bolts safe to run on dropped steering arms? I'm using 1/2-20 fine thread with lock washers and blue lock-tite on mine, and I want to ensure that there will be no issue.
    Also. Is it ok to use different grade nuts on different grade bolts? i.e. grade 5 bolts, grade 8 nuts.
  2. junk yard kid
    junk yard kid
    im gunna go with no
  3. <TABLE dir=ltr cellSpacing=0 cellPadding=7 width=625 border=1><TBODY><TR><TD vAlign=center colSpan=21 height=35>
    Bolt Grade Markings and Strength ​
    </TD></TR><TR><TD vAlign=center colSpan=21 height=29>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    American ​
    [/FONT]​
    [/FONT]​
    </TD></TR><TR><TD vAlign=center width="20%" colSpan=3 height=91>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    Head Markings ​
    [/FONT]​
    [/FONT]​
    </TD><TD vAlign=center width="20%" colSpan=5 height=91>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    Grade or Class ​
    [/FONT]​
    [/FONT]​
    Material ​
    [/FONT]​
    [/FONT]​
    Nominal Size Range ​
    [/FONT]​
    [/FONT](Inches)
    </TD><TD vAlign=center width="20%" colSpan=3 height=91>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    Mechanical Properties ​
    [/FONT]​
    [/FONT]​
    </TD></TR><TR><TD vAlign=center width="33%" colSpan=6 height=76>[FONT=HNAGDO+Arial,Bold,Arial]
    Proof Load ​
    [/FONT](psi)
    </TD><TD vAlign=center width="33%" colSpan=8 height=76>[FONT=HNAGDO+Arial,Bold,Arial]
    Minimum Yield Strength ​
    [/FONT](psi)
    </TD><TD vAlign=center width="33%" colSpan=7 height=76>[FONT=HNAGDO+Arial,Bold,Arial]
    Minimum Tensile Strength ​
    [/FONT](psi)
    </TD></TR><TR><TD vAlign=center width="14%" height=87>
    No Markings ​
    </TD><TD vAlign=center width="14%" colSpan=4 height=87>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    Grade 2 ​
    [/FONT]​
    [/FONT]​
    Low or Medium Carbon Steel ​
    </TD><TD vAlign=center width="14%" colSpan=3 height=87>
    1/4 thru 3/4 ​
    55,000 ​
    57,000 ​
    </TD><TD vAlign=center width="14%" height=87>
    74,000 ​
    </TD></TR><TR><TD vAlign=center width="25%" colSpan=4 height=26>
    Over 3/4 thru 1-1/2 ​
    </TD><TD vAlign=center width="25%" colSpan=7 height=26>
    33,000 ​
    </TD><TD vAlign=center width="25%" colSpan=6 height=26>
    36,000 ​
    </TD><TD vAlign=center width="25%" colSpan=4 height=26>
    60,000 ​
    </TD></TR><TR><TD vAlign=center width="14%" height=84>
    3 Radial Lines ​
    </TD><TD vAlign=center width="14%" colSpan=4 height=84>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    Grade 5 ​
    [/FONT]​
    [/FONT]​
    Medium Carbon Steel, Quenched and Tempered ​
    </TD><TD vAlign=center width="14%" colSpan=3 height=84>
    1/4 thru 1 ​
    85,000 ​
    92,000 ​
    </TD><TD vAlign=center width="14%" height=84>
    120,000 ​
    </TD></TR><TR><TD vAlign=center width="25%" colSpan=4 height=14>
    Over 1 thru 1-1/2​
    </TD><TD vAlign=center width="25%" colSpan=7 height=14>
    74,000 ​
    </TD><TD vAlign=center width="25%" colSpan=6 height=14>
    81,000 ​
    </TD><TD vAlign=center width="25%" colSpan=4 height=14>
    105,000 ​
    </TD></TR><TR><TD vAlign=center width="14%" height=75>
    6 Radial Lines ​
    </TD><TD vAlign=center width="14%" colSpan=4 height=75>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    Grade 8 ​
    [/FONT]​
    [/FONT]​
    Medium Carbon Alloy Steel, Quenched and Tempered ​
    </TD><TD vAlign=center width="14%" colSpan=3 height=75>
    1/4 thru 1-1/2 ​
    120,000 ​
    130,000 ​
    </TD><TD vAlign=center width="14%" height=75>
    150,000 ​
    </TD></TR><TR><TD vAlign=center width="17%" colSpan=2 height=81>
    Stainless markings vary. Most stainless is non-magnetic ​
    </TD><TD vAlign=center width="17%" colSpan=5 height=81>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    18-8 Stainless ​
    [/FONT]​
    [/FONT]​
    </TD><TD vAlign=center width="17%" colSpan=4 height=81>
    Steel alloy with 17-19% Chromium and 8-13% Nickel ​
    1/4 thru 5/8 ​
    80,000 – 90,000 ​
    </TD><TD vAlign=center width="17%" colSpan=2 height=81>
    100,000 – 125,000 ​
    </TD></TR><TR><TD vAlign=center width="33%" colSpan=6 height=35>
    3/4 thru 1 ​
    </TD><TD vAlign=center width="33%" colSpan=8 height=35>
    45,000 – 70,000 ​
    </TD><TD vAlign=center width="33%" colSpan=7 height=35>
    100,000 ​
    </TD></TR><TR><TD vAlign=center width="50%" colSpan=10 height=14>
    Above 1 ​
    </TD><TD vAlign=center width="50%" colSpan=11 height=14>
    80,000 – 90,000​
    </TD></TR><TR><TD vAlign=center colSpan=21 height=36>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    Tensile Strength: ​
    [/FONT]​
    [/FONT]The maximum load in tension (pulling apart) which a material can withstand before breaking or fracturing. [FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]Yield Strength: [/FONT][/FONT]The maximum load at which a material exhibits a specific permanent deformation [FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]Proof Load: [/FONT][/FONT]An axial tensile load which the product must withstand without evidence of any permanent set.
    </TD></TR></TBODY></TABLE>
    <DIR><DIR><DIR><DIR><DIR><DIR><DIR><DIR><DIR><DIR>[FONT=HNAGDO+Arial,Bold,Arial]
    800 472 7373 ​
    </DIR></DIR></DIR></DIR></DIR></DIR></DIR></DIR></DIR></DIR>
    [/FONT]<TABLE dir=ltr cellSpacing=0 cellPadding=7 width=625 border=1><TBODY><TR><TD vAlign=center colSpan=19 height=35>
    </TD></TR><TR><TD vAlign=center colSpan=19 height=29>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    Metric ​
    [/FONT]​
    [/FONT]​
    Head Markings ​
    [/FONT]​
    [/FONT]​
    </TD><TD vAlign=center width="20%" colSpan=4 height=91>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    Grade or Class ​
    [/FONT]​
    [/FONT]​
    Material ​
    [/FONT]​
    [/FONT]​
    [/FONT]​
    [/FONT](Inches)
    [/FONT]​
    [/FONT]​
    Proof Load ​
    [/FONT](psi)
    [/FONT](psi)
    </TD><TD vAlign=center width="33%" colSpan=5 height=76>[FONT=HNAGDO+Arial,Bold,Arial]
    [/FONT](psi)
    </TD></TR><TR><TD vAlign=center width="14%" height=69>
    8.8 ​
    </TD><TD vAlign=center width="14%" colSpan=3 height=69>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    Class 8.8 ​
    [/FONT]​
    [/FONT]​
    </TD><TD vAlign=center width="14%" colSpan=4 height=69>
    All Sizes thru 1-1/2 ​
    85,000 ​
    92,000 ​
    </TD><TD vAlign=center width="14%" height=69>
    120,000 ​
    10.9 ​
    Class 10.9 ​
    [/FONT]​
    [/FONT]​
    120,000 ​
    130,000 ​
    150,000 ​
    </TD><TD vAlign=center width="17%" colSpan=3 height=81>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    A-2 Stainless ​
    [/FONT]​
    [/FONT]​
    1/4 thru 5/8 ​
    80,000 – 90,000 ​
    100,000 – 125,000 ​
    3/4 thru 1 ​
    45,000 – 70,000 ​
    </TD><TD vAlign=center width="33%" colSpan=5 height=35>
    100,000 ​
    Above 1 ​
    </TD><TD vAlign=center width="50%" colSpan=9 height=14>
    80,000 – 90,000​
    </TD></TR><TR><TD vAlign=center colSpan=19 height=36>[FONT=HNAGDO+Arial,Bold,Arial][FONT=HNAGDO+Arial,Bold,Arial]
    Tensile Strength: ​
    [/FONT]​
    not really what I wanted to do but this may help.....I try to use mostly grade 8 I bought a pretty big assortmet a few years ago.. My feeling is
    "when in doubt,build it stout"
  4. 37RAT
    37RAT
    from Wisconsin
    Depends if you want to play it safe or not, why skimp on something your life depends on. I would personally not take chances, spend a little extra and use grade 8 bolts and nuts.
  5. striper
    striper
    I'm thinking grade 5 will probably be OK.
    When I'm driving my car down the road at 80mph, I'll be thinking "Mmmm, those grade 5 bolts on my steering arms will probably be OK"
    You decide.
  6. I have to say Yes. This has been debated on here before. Many OE's have used a grade 5 bolt in this application. A Grade 5 1/2 bolt has a yeild strength of 46,000 lbs and a Tensile strength of 60,000 lbs.
    If your steering arms see that kind of load, you got bigger problems to worry about.
  7. roundvalley
    roundvalley
    Now this will keep you awake at night! Go grade 8. Bet there is a tractor dealer close to you. Pay him a visit!
  8. Gary in da UP
    Gary in da UP
    Sure the chinese do it all the time! Do you know where your bolts come from?!
  9. choppintops
    choppintops
    X2 :cool:
  10. Johnny1290
    Johnny1290
    Honestly unless you bought them from a fastener store they're probably bogus anyhow, or at least that's what Carroll Smith says from his book, and I believe him.
    If you're really worried get some bolts from someplace like an aircraft surplus or hotrod shop or something...I bought fasteners at a surplus shop and they're $$$ but the quality is just unreal
  11. Sincity57
    Sincity57
    from Austin
    x3!
  12. V4F
    V4F
    from middle ca.
    i like grade 8's on things of importance . but im an over doer . been racing to long , its a habit .................. steve
  13. tromper
    tromper
    For just a few dollars more, you can be sure!
    Go grade 8
  14. model-a-fan
    model-a-fan
    from Kentucky
    OK i'm going with the grade 8 to be safe. I did run into another problem. The bolt head touches off on the bottom of my axle when I turn the spindle. How much travel should the spindles have? Any suggestions?
  15. It depends on your steering set up and whether you have stops or not.
    (and the grade 5 are still fine:cool:)
  16. model-a-fan
    model-a-fan
    from Kentucky
    I don't have stops.
  17. Do you have your steering gear hooked up? It will probably limit the travel from causing the issue you are talking about.
  18. model-a-fan
    model-a-fan
    from Kentucky
    Here's pic.s of the issue. Circled in red is the touch point on both sides.
  19. model-a-fan
    model-a-fan
    from Kentucky
    hotroddon,
    No, axle is out of the car.
  20. Red Ryder
    Red Ryder
    Momma always said, "Better safe than sorry". When it comes to fasteners, it never hurts to go for the best. The price difference is PPPHHHTTTT! ;)
  21. model-a-fan
    model-a-fan
    from Kentucky
    Does anyone have a pic of a steering stop set-up? I'm not sure I know what they look like.
  22. JC Sparks
    JC Sparks
    from Ohio
    The price of the grade 8 bolt is just a few cents more than the 5's. As far as the nuts go always use a nut rated at or above the bolt. Then torque them to speck, loctite works as a lubrication when torquing. JC
  23. model-a-fan
    model-a-fan
    from Kentucky
    I appreciate all the input guys!
  24. QMOTOX
    QMOTOX
    from STL, MO
    Good choice on the CE arms. I can see now why you had a big issuse with the speedway arms before.
    Its hard to tell from that pic but it looks like you have enough steering throw. Could you get a pic from like strait down on the kingpin?
    I wouldn't worry about that bolt hitting at the stage your at now. Get a little father along and I think you'll find either your steering set up doesn't have enough throw to make it hit or the tire will hit your radius rod/hairpin before that bolt hits.
  25. Weasel
    Weasel
    For me it's a really easy decision:
    Cheap Grade 5 bolts $5, expensive Grade 8 bolts $10, staying alive - priceless...
  26. HAMB metallurgist advice:
    Grade 5 is fine, but grade 8 is better. Don't use stainless for critical suspension application like this
    Now some education on bolts: Grade 5 are not heat treated, they get their strength increase from the better material than Grade 2 and form the cold working during the boll forming process. Grade 8 are heat treated, making them stronger. Both have rolled threads typically, which is always better than cut threads for strength and fatigue crack resistance. Grade 8 should be rolled threads after heat treat, not before. Similar for metric 8.8 vs 10.9.
    Stainless is only increased strength from work hardening, but they are lower strength than Grade 5. Better than Grade 2, but less than Grade 5.
    Most all bolts are zinc plated. The silver color has clear chromate (makes a real slight blue tint if you open a new box and see them all together. Yellow chromate is better for corrosion resistance, can be yellow to gold color. There is also olive drab (even better corrosion resistance) and black chromate. Yellow chromate is what used to be used on cadmium plated parts, slang term "gold cad plated". Cad plating is actually silver, the chromate makes it colored. Cad is not used for commercial applications anymore, about the only use is for aerospace and some marine. Zinc is fine for our hot rod use.
  27. Retro Jim
    Retro Jim
    For a few dollars more go with grade 8 and don't be cheap with your life !
  28. temper_mental
    temper_mental
    from Texas
    Lets just say you use grade five. And tomorrow you drop over with a heart attack and later one of your family members wants to take the car out for a ride and finds out grade 5 will not cut it. I always like to over build. My 2 cents
  29. If in doubt, go grade 8 (six marks on the head), grade 5 (3 marks).
  30. Weasel
    Weasel
    Grade 8 have five line marks on the head and are usually yellow chromate.
